Does Acrobat 7 Pro works with Window 8
jkcal
I have Acrobat 7 Pro and was told Window 8 works, when I install in it said "Setup has detected that you already have a more functional product installed. Setup will now terminate.
Anyone know how to fix it? Thanks for the help ahead.
Hi there
Do you perhaps have a version of Adobe Reader installed that is newer than version 7?
If so, then choose run the setup again, choose custom and deselect the option to use Acrobat 7 Pro as the default PDF reader. It should then install.
