Hello everyone.
I have moved from Europe to Canada recently and i took my PC with me. One day when i was playing the computer shut off, and the problem was the power supply. I thought that mine was dead, and i thought so because i used a cheap adapter from European plug to American one, so i bought a new power supply and everything is fine now.
However, my friend recently took a look at the inside of the power supply and he said that nothing seems to be defective and the power supply might actually work. So here is my question - If i buy a power cable with american plug, assuming that the power supply isn't dead, will it work? The power supply input current is rated at 230Vac, and i assume that lower input current of 110 in Canada will be no problem?
An example of american power cord - https://www.amazon.com/C2G-03134-Universal-Power-Cord/dp/B00005113L?ref_=Oct_DotdC_i78c_0_11572a9b&pf_rd_p=d33831d1-957a-5043-9c10-6db8567a8615&pf_rd_s=merchandised-search-4&pf_rd_t=101&pf_rd_i=597260&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=TA3ZSBC01EM0T8CPRVVM&pf_rd_r=TA3ZSBC01EM0T8CPRVVM&pf_rd_p=d33831d1-957a-5043-9c10-6db8567a8615
Power supply itself and its specifications - https://www.coolermaster.com/catalog/legacy-products/power/thunder-500w/#Specifications
