Does Moz/xe send a keep alive ping?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
When and only when Mozilla is active every 15 seconds my computer pings
the following-
TCP:127.0.0.1:xxxx
which is - This block is assigned for use as the Internet host
loopback address. A datagram sent by a higher level protocol to an
address anywhere within this block should loop back inside the host.
This is ordinarily implemented using only 127.0.0.1/32 for loopback,
but no addresses within this block should ever appear on any network
anywhere
Which seems to indicate that either Moz or windows XE is pinging to
continue to check my IP address and keep the line open. My guess is
windows xp and its network protocol.
Which is it and what process is responsible? Is it necessary this often?
I did not notice it with win 98se, but that does not mean it was not
going on.
BTW- tested the computer with shields up and all stealth. Plus ran
spybot, adaware, asquared and AVG with no hits. Running behind a router
and zonealarm.
GA
My address is spoofed, so do not reply directly.
That is a local I.P address so traffic is not going out to the Internet.
Are you seeing this as an error in your firewall ?
> the following-
> TCP:127.0.0.1:xxxx
> anywhere
> going on.
> and zonealarm.
> GA
No.
>>the following-
>>TCP:127.0.0.1:xxxx
>> anywhere
>>going on.
>>and zonealarm.
>>GA
Also, it does not do this in MSIE, only Mozilla, so somethig is set in
Mozila to ask. I have checked the Moz settings and cannot find anything.
GA
Gordon Abbot wrote:
> No.
>>> pings the following-
>>> TCP:127.0.0.1:xxxx
>>> anywhere
>>> going on.
>>> router and zonealarm.
>>> GA
> the following-
> TCP:127.0.0.1:xxxx
> anywhere
> going on.
> and zonealarm.
> GA
It would be useful for us to know how you are connected to the Net i.e
dialup, cable, adsl etc and wether you are using router.
I personally would hazard a guess and say that you need to check your
setup of Mozzilla and ensure that automatic discovery of proxy is not
enabled. Please not more info would be a help here in regards to the
type and method of connection.
>> TCP:127.0.0.1:xxxx
>> anywhere
>> going on.
>> GA
Sorry- cable modem with router and zone alarm firewall with not much
more than Mozilla allowed. All other programs have to ask. I am not
getting any zonealarm popups requesting permission to connect to the
Internet.
I do have the automatic discovery IP address enabled in XP.
GA
Fixed. It was a Mozilla advanced http setting that sends a keep alive
signal every 15 seconds. One check mark and all gone.
GA
> GA
> Gordon Abbot wrote:
>> No.
>>>> TCP:127.0.0.1:xxxx
>>>> anywhere
>>>> often?
>>>> going on.
>>>> GA
> GA
>> GA
>> Gordon Abbot wrote:
>>> No.
>>>> Internet.
>>>>> TCP:127.0.0.1:xxxx
>>>>> host.
>>>>> loopback,
>>>>> network
>>>>> anywhere
>>>>> often?
>>>>> not going on.
>>>>> GA
MMMM - Which setting was the offender under the advanced section?
>> GA
>>> in Mozila to ask. I have checked the Moz settings and cannot find
>>> anything.
>>> GA
>>> Gordon Abbot wrote:
>>>> No.
>>>>> Internet.
>>>>>> TCP:127.0.0.1:xxxx
>>>>>> to an
>>>>>> host.
>>>>>> loopback,
>>>>>> network
>>>>>> anywhere
>>>>>> to continue to check my IP address and keep the line open. My
>>>>>> guess is windows xp and its network protocol.
>>>>>> often?
>>>>>> not going on.
>>>>>> GA
edit/preferences/advanced/http processing and the keep alive check box
is right there.
Everything is easy when you know where to look.
GA
