Hi looking at the D15S model by noctura and was going to get an additional fan to put on the outside since it is optional. I am going to go with a 120mm fan since clearance is better. My question is does the fan need a high pressure rating ? I ask because the cooler is set up as Radiator-FAN-Radiator-FAN-Open Space.
Do you need a high pressure fan blowing on the radiator even when behind the fan you have all the clearance you could wish for?
thanks
J
thanks
J
