[SOLVED] Does Noctua NH-15 Fit my case?
Hiper1995
41
Hello,
Its my first time i`m buying a cooler, so i thought i should be 100% sure that it fits my case.
Cooler that i want to buy: Noctua NH-15
My current case: DeepCool Kendomen TI Windowed Titanium Grey
Case dimensions: 491 x 200 x 486mm
Motherboard: B350 Tomahawk
RAM: Patriot Viper 4 2x8GB DDR4 3200MHz CL16 Dual Channel pv416g320c6k
RAM dimensions: 133 x 7.1 x 42.6mm
I want to be able to use both the fans of the cooler.
Thanks in advance !
