[SOLVED] Does pcie 1x to 4x have the same speed?
Sauce109
Commendable
Jul 25, 2019
44
So if I buy an adapter that is a pcie 1x to 4x and I plug in an m.2 drive, will it be slower? If the m.2 is slower, then how much slower would it be if it’s nvme? If the m.2 would be to slow, could I put a network card in it?
You're switching interfaces, but the underlying connection via the PCIe slot in this instance remains x1 whereas an SSD can typically utilize speeds right around x4 (Gen3), although some older will cap out at Gen2 x4 (which is equal in bandwith to Gen3 x2). Either way, and x1 interface is going to limit any M.2 SSD.
How much slower, really depends. Might only test as slower in benchmarks, but I'd expect it to be noticeable in day-to-day use.
Why are you considering an adapter? What motherboard do you have? Do you already own the M.2?
If you don't already own the M.2, the cost + adapter is a waste. You'd be best served by a 2.5" SATA based SSD.
As far as a network card goes, generally, yes. Networking is a more appropriate use-case...
As far as a network card goes, generally, yes. Networking is a more appropriate use-case for x1.
So would it run at 1/4 the speed it should?
Rarely will it scale linearly with limited lanes, but in a very simplistic sense, you could use that as a (very) rough idea.
Reactions: CountMike
Right now I am going to use a SATA 2.5 inch, but I might want to get an m.2 nvme. I was thinking maybe I could get a 1x to 4x so that I could use a network card. I didn’t want to use a 1x network card because they all stick out of your computer.
