Question Does the Ryzen 5 7600X work well on an MSI PRO A620 motherboard ?
F1080
21
Hello,I have seen many reviews that say the Ryzen 5 7600X doesn't work well with the MSI PRO A620 mobo. So I was wondering if this is true or not?
And how to know if this CPU is working at its maximum performance with this mobo without hindering it's speed or any little bit of this CPU'S performance, and if there is any program or application that can show this?
Specs
Mobo: MSI PRO A620 M-E
CPU: Ryzen 5 7600X
GPU: GIGABYTE GTX 1080 TI
RAM: PATRIOT VIPER VENOM (2 x 8GB) 5200MHz
CPU Cooler: Cooler Master Hyper 212 Turbo led ARGB
OS: Windows 10 64-bit
Thanks in advance
You should aim for a B650 chipset if you're looking at a Ryzen 7600x. I would pair the A620 chipset with a 7600(non-X and lower). You forgot to mention the make and model of your PSU and it's age as well as a link to your ram kit. You should look into a dual channel DDR5-6000MHz AMD E.X.P.O advertised ram kit to pair with an AM5 build.
AMD's Ryzen Master, if you want to monitor, I wouldn't overclock on that platform of yours.
I'm not aiming for overclocking my CPU at all. I just want to make sure it's working normally at its normal speed and performance. So, do you think the A620 would be able to handle this without any problems or the b650 is a must?
My PSU model is Xigmatek X Power 700 watt which I recently purchased .
I tried installing AMD's Ryzen Master several times but it always says installation failed?
