[SOLVED] Download/Upload speed halved when using router?
Aaron_10
4
Hello! I have an ASUS AC1900 AC68U router. Unfortunately, when I use this router, I'm getting my upload/download speeds halved.
Here are my results when directly plugged into the modem
View: https://imgur.com/imfbYGK
Here are my results when plugged directly into the router
View: https://imgur.com/7QPvzSI
As you can see, it's almost exactly halved. Anyone know the culprit of this?
EDIT to the main post! 10/21/2020
I tried running a speed test on my phone using WiFi and sitting less than 3 feet away from the router and here are the awful results I've gotten on an iPhone 11 Pro Max
View: https://imgur.com/8FMwP3F
Aaron_10
4
If anyone else stumbles across this post, I ended up getting the full speeds by downloading the phone app and updating the BIOS this way. Very easy and didn't have to hunt for a flash drive.
SteveRX4
Notable
BANNED
Sep 29, 2020
1,477
135
890
20
I gather you have an ethernet cable connected from your ISP modem to the AC1900 wan input?
And your AC1900 is connected by ethernet cable or wifi to your PC?
Have you set up your router on your PC?
Aaron_10
4
Correct, the PC is connected via ethernet to my router, and router is connected to modem via ethernet.
The router is fully set up with my own network.
Aaron_10
4
