Question DRAM light is on and no signal
Dec 25, 2019
I built a new pc and started it up, all the fans were spinning but the DRAM light was on and I was getting no signal. The ram is correctly installed and in the correct dimm slot, ive tried resetting the cmos but that didnt work. My parts are all compatible but i still dont know whats wrong, any solutions?
EDIT: Took everything apart and rebuilt it, the DRAM led is off but im still getting no signal
Can you list PC specs please and describe everything connected to the motherboard from psu and which slots the ram are in.
i3 9100f
B365M PRO-VDH
(2x8) Corsair Vengeance 2400 Mhz ddr4 ram
MSI Armour RX 570
Thermaltake Litepower 550W PSU
Im only using 1 ram stick in the DIMMA2 slot as said by the manual
i took out all of the components and put it back together and the DRAM led is off but im still getting no signal
