DSL CONNECTION SPEED NOT UP TO PAR
Nitrom
121
I recently got DSL from my ISP and I am using the kit they send me (with the DSL modem included) but the theorical connection speed of 1000 KBPS is more like 420 KBPS according to the CNET test speed....
Will buying a DSL MODEM from a store give me better connection speeds?....thanks for the help
Those online test are not always accurate. I suggest downloading something large from a known fast server and seeing what your kilobytes/s is. You can take that and multiply it by 8 to get your kilobits/s. If you get somewhere around 125kilobytes/s downloads then you are getting the rated speed.
I find <A HREF="http://www.dslreports.com" target="_new">dslreports.com</A> to have more accurate speed tests if you just want to run more speed tests.
<A HREF="http://www.folken.net/myrig.htm" target="_new">My precious...</A>
no, but I have had faster thouroughput with Cable connections.
I get 3000mb second for $45 month, and have not seen DSL speed/price ratio anywhere near this.
<font color=red><pre>_____________________________________
And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign</pre><p></font color=red>
