Dual molex to 6 pin pcie for xfx rx 470
Aftmost
12
I have a logisys case with the psu that comes with it the case is Logisys 380 SOHO ATX and my pc specs are
cpu: fx 8320 e
mem: 4gb crucial 1600
mobo: asrock 970m pro3
psu:http://www.bhphotovideo.com/images/images2500x2500/logisys_ps480d_bk_480w_black_beauty_atx_1096553.jpg
I didn't know how to show the psu any better but pls tell me if this works or not, I really hope this does also made a part list here's that:
https://pcpartpicker.com/user/bailey13m/saved/rXjD3C
I also bought the adapter already but need to save for the 470 and I'm having doubts if this works but here's the adapter:https://www.walmart.com/ip/BattleBorn-GC-POW-ADT-PCIE-7-PCI-Express-Power-Adapter-2-x-4-Pin-Molex-to-6-pin-PCI-E-Power/47517664
16 AMPS ON THE 12+ rail isn't enough , a bad idea to even try it , and that company only produces very very poor power supplies. And I doubt the specs on that PSU are accurate.
You need a decent 450w power supply that has the PCIE cable to power it , not an adapter.
In the end it's your choice , but I wouldn't risk it.
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ Amazon)
Total: $49.99
Generated by PCPartPicker 2017-05-03 21:16 EDT-0400
or
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply ($34.90 @ Newegg)
Total: $34.90
Why doesn't it have enough power for the 470? it doesn't have a 6 pin pci-e connector? just btw I bought one if u didn't see but yeah why doesn't it have enough power?
It's too weak on power and also has a very poor 12v+ rail , it's not designed to run cards. I wouldn't power any build with it. Adapters are a very bad idea on a weak low quality PSU.
This is what happens in that scenario.
[video="https://www.youtube.com/watch?v=Ezk9OA7aKOE"][/video]
The label on the psu says 12v rail max combined w is 330 and pc part picker says 304w
