Dual monitor issue - not detecting second monitor
ocmyers
19
For one reason or another I am unable to get both displays working at the same time but they both work perfectly when plugged in separately. When I try and detect another monitor it just comes back 'none detected'. They are both the same model (dell 1704FPt - yay, freebies).
I don't know how helpful this will be but this is what I have:
- Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W)
- MSI GeForce GTX 660 Black Knight 2048MB GDDR5 PCI-Express Graphics Card
- Asus P8Z77-I Deluxe (Socket 1155/Intel Z77.DDR3/S-ATA 600/Mini ITX)
- Corsair 2013 Edition Gamer Series GS 800W '80 Plus Bronze' Power Supply (CP-9020065-UK)
It is definitely detecting something because when I plug it in the screen changes from the floating text box to a blank screen.
Hope someone can help! Thanks in advance or any advice.
Hello... Pictures are good, but can you answer the following questions First?
1) you have TWO options for Dual monitor display output physical connections, Pick one...
a) Intel CPU/IGT MB & GTX 660 Video card.
b) GTX 660 Video card & GTX 660 Video card.
2) What type of physical connections are on your Monitors?
a) VGA
b) DVI
c) VGA & DVI
d) HDMI
e) ALL of the above
3) What Type of Video cables do you currently have?
a) VGA
b) DVI
c) HDMI
d) All of the above
4) What type of Video Adaptors do you have?
a) VGA to DVI cable
b) DVI to VGA cable
c) DVI to HDMI cable
d) HDMI to DVI cable.
The best Digital Picture would be to NOT use any VGA ( analog ) adaptors or Cables with your setup, but this depends on your monitors connectors, and...
Hello,
Thank you for your reply. I am using VGA to DVI cables. I am not sure what you mean by the other questions. How can I find out that information? Would it help if I sent picture of the back of my computer and showed which adapters etc I am using?
a) VGA
b) DVI
c) VGA & DVI
d) HDMI
e) ALL of the above
a) VGA
b) DVI
c) HDMI
d) All of the above
a) VGA to DVI cable
b) DVI to VGA cable
The best Digital Picture would be to NOT use any VGA ( analog ) adaptors or Cables with your setup, but this depends on your monitors connectors, and being able to use a DVI or HDMI cable with them.
