[SOLVED] Dual Monitor Problem
matthewrandall
4
I want to have dual displays so I can multi task better. My GPU on has 1 hdmi but has a VGA and both TVs only have hdmi. I have ordered a splitter and it mirrors my screen which I do not want. Could I use a HDMI to VGA cable instead? Have the HDMI to HDMI from one TV and HDMI to VGA in the other?
You can use the VGA output but not with just a cable, certainly not an HDMI to VGA cable. You must look it for the direction the signal travels, computer to monitor, and get a VGA to HDMI converter. It will have a little box on it that converts the analog VGA from the computer to digital HDMI. So you'll have one HDMI to HDMI, and one VGA to HDMI through a converter box built into the cable.
So could I just buy one of these? https://www.amazon.co.uk/Gold-Plate...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
