e-Machine stuck in continual loop
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
"kyle" <kyle.1s1kdv@pcbanter.net> wrote in message
news:kyle.1s1kdv@pcbanter.net...
> After typing "dir" at the A: prompt, I see dcpromo.log.txt listed as one
> of the files. I typed "copy dcpromo.log c:\windows\debug", but once
> again it said it can't locate the file. I'm wondering if this is
> because on the drive it's being listed as dcpromo.log.txt. I took the
> disk and put it in the other computer. I checked the file name, which
> is dcpromo.log. Then I checked its properties. It's attribute is
> Archive. And its msdos name is dcpromo.log.txt. Should I change my
> command line to "copy dcpromo.log.txt c:\windows\debug"? I tried
> renaming the file with no success.
> -Kyle
Hi Kyle,
that is really weird Kyle. The msdos name, dcpromo.log.txt, is the reason
why the copy command is not working in the Recovery Console and it would
almost certainly copy if you used
But that is not any good because its the presence of a file with the name
dcpromo.log that blocks the vulnerability in the Lsass process. I will see
if I can find out why this name issue is occuring. Trouble is Kyle this was
intended as a test and Lsass may not be your problem, particularly as you
have SP2 installed. I'm conscious of the time this is taking you so maybe a
different approach is needed here.Consider this
http://www.webtree.ca/windowsxp/repair_xp.htm
and select how to run a repair install from the list. Might be worth a go.
Remember to disconnect your machine from the Internet if you do this and
after the repair-if Windows starts reapply SP2 before reconnecting to the
Internet. Also reapply all hotfixes released after SP2. Good luck Kyle
Chelsea
Hi Kyle,
I was wondering if any of these suggestions solved your computer problem. I
am still trying to resolve mine.
nlee788
> -Kyle
> Chelsea Wrote:
> > "kyle" kyle.1rxv1n@pcbanter.net wrote in message
> > news:kyle.1rxv1n@pcbanter.net...-
> > I copied the dcpromo.log onto Disk 6 as you advised. I booted up
> > with
> > the disks and got to the Recovery Console. I typed the commands as
> > you
> > advised. Unfortunately, the computer said it couldn't find the file.
> > I
> > double-checked the disk using the other computer. The file
> > dcpromo.log
> > definitely exists. I exited, and as before my computer went into its
> > loop. And it won't boot up Windows in Safe Mode, either. Oh well. .
> > Looking forward to your reply.
> > Kyle
> > Hello Kyle,
> > I am foxed as to why that doesn't work. The dcpromo.log file is
> > normally
> > installed from within Windows, but as you are unable to get into
> > Windows, I
> > modified things to use the Recovery Console. If you would be prepared
> > to
> > persevere with this a little and can face another 10 minutes of tedium
> > with
> > the recovery console try this. Incidently I just tried this on a
> > laptop
> > using a USB A drive and can assure you it does work.
> > In the Recovery Console type the following at the c:\windows prompt
> > With diskette 6 in the drive type
> > a:
> > then type dir-can you see dcpromo.log on the diskette?
> > Now type
> > Type c: and return -that takes you back to c:\windows prompt
> > Finally type
> > attrib +r c:\windows\debug\dcpromo.log
> > Type exit
> > Remove the diskette from the 3.5 inch drive and see what happens when
> > Windows restarts.
> > What I am trying to do is plug a vulnerability in the lsass service,
> > which I
> > think may be crashing everytime you start Windows. This is well known
> > and
> > causes the infinite loop that you are experiencing. So lets see how it
> > goes.
> > Chelsea
> kyle
Sorry for the delay getting back to you. I've been having an
existential crisis with this computer thing. I need to ask you one
thing before attempting the Repair Install of Windows XP. I don't have
the Windows XP installation CD. All I have are the 6 boot disks that
I'm using to access the Recovery Console. Can I still proceed with the
Repair Install with only my boot disks? The link
http://tinyurl.com/1h7d
seems to make use of the CD.
Still hanging in there,
Kyle
Chelsea Wrote:
> "kyle" kyle.1s1kdv@pcbanter.net wrote in message
> news:kyle.1s1kdv@pcbanter.net...-
> one
> the
> which
> -Kyle-
> Hi Kyle,
> reason
> would
> name
> see
> was
> you
> maybe a
> go.
> and
> the
> Chelsea
kyle
Hi Kyle,
Sorry if you don't have an installation CD you cannot do the repair I
directed you towards. All is not lost however, particularly if you have
System Restore switched on. If you have never touched it then it will be on
by default. What you can try is putting a different registry in place and
doing a system restore. This might get your system back ? Wish I could say
this will get it back, but there is not very much to be lost by trying. If
you want to try look at this http://support.microsoft.com/?kbid=307545#kb1
I know you are not getting the error messages mentioned, but this technique
will give you access to a recent system restore point and a newish registry
Best of luck and keep us informed.
Chelsea
"kyle" <kyle.1s8idt@pcbanter.net> wrote in message
news:kyle.1s8idt@pcbanter.net...
> Kyle
