So... My friend told me about overclocking and I tried it.
At first I put it on 2.4 GHz(266•9) and it worked. Then I wanted to make it more and now I have a problem.
Whatever I do with CPU Host Frequency(raising it or lowering it) it doesn't make a change. It is always 200•CPU Clock Ratio(If i put the Clock ratio to 10 than its 2 GHz).
These are my M.I.T. specs:
Robust Graphics Booster - Auto
CPU Clock Ratio - 8x
CPU Frequency - 2.40GHz(300x8)
CPU Host Frequency(MHz) - 300
PCI Express Frequency(Mhz) - 100
Performance Enhance - Standard
System Memory Multiplier (SPD) - 2.66
System Voltage Control - Manual
DDR2 OverVoltage Control - Normal
FSB OverVoltage Control - Normal
CPU Voltage Control - 1.27500V
Normal CPU Vcore - 1.32500V
So my CPU Frequency is 1.6GHz at the moment (200•8) and I would like to raise it to 2.6/2.7 GHz.
Please someone tell me what I need to do.
