Question Each and every time have to press monitor power button to turn my benq lcd display
11
Hi,
Normal lcd displays turns on itself once cpu power is turn on but in my benq lcd display I have to manually press power button on that benq lcd display to turn on the display each and every time so frustrating.
Lcd display model is benq G610hda
I have reset the display settings
Installed lcd driver from benq website.
I have no clue further proceed.
Intel Core2Duo
DG41RQ MoBo
3gb RAM
500gb hdd
Likely, your power supply and motherboard are not sending sufficient residual power to the monitor to allow it to start up.
Not much you can do about that.
Possibly, there are some power settings in the motherboard bios.
There also may be a motherboard bios update that addresses the issue.
Why not leave the ups on?
See if that helps.
Do you really need to shut down?
Why not try sleep to ram(no hibernate)instead.
That puts the pc and monitor into a very low power state, not very different from a full power off.
As an added bonus, sleep/wake is much faster.
See if that helps.
I can't leave the UPS at power on stage.its the display driver the one should send signal to display that I have install already but it's not sending signal.
