G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
From my project blog at http://williamsgrandprix.blogspot.com/
Feel free to answer here on RGP or in a blog comment. Thanks!!![Smile :) :)](/data/assets/smilies/smile.gif)
Okey, I've read the PinballHQ EM repair guide, and it's pretty strict on
lubrication:
Electro-Mechanical machines, for the most part, do not require any
lubrication. Most parts run "dry". Far more damage can be done to a
machine by over-lubricating, than by under-lubricating. As a rule, if in
doubt as to lubrication, don't do it! ... The only parts that will
require any lubrication are metal-to-metal moving parts. There aren't
very many in an EM game. So keep that lubrication in the tool box and
away from the game.
So far I've stayed clear of any oil, but after going over some of the
stepper units and drop targets in the machine I'm starting to wonder if
maybe these classify as "metal-to-metal" moving parts. Small shafts that
are supposed to move without any friction are very slugish and almost
stuck, and I'm not sure how to fix this. They seem to have been oiled
some time in the past, but that might have been a mistake? So, should I
oil these parts, or should they be cleaned and sanded?
I'm spesifically talking about the drop target mechanical joints and the
shafts in the stepper units.
Oil, or no oil? And if no oil, what to clean it with to remove the old
oil and how to make it's movement smooth and without friction? I guess
that is the question.
Tor Arne
lubrication:
away from the game.
Tor Arne
