Engine Executable Errors
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.games (More info?)
I have quite a few games that I like to play, and I thought that getting
another computer would make things run easier. Boy was I wrong. Ever since
I got this computer, which by the way came with Windows XP, none of the games
ever work right. They either won't load at all, or they cut out with these
Engine Executable Errors all the time. Someone mentioned that there was a
way to force XP to run in a different Windows format, but they didn't know
how to do it. I'm so fed up with this already. I've gotten to the point
where I'm going to buy a different Windows format just so I don't have to
deal with this anymore. Help! Is there a way to do this, or something you
can suggest to stop this from happening?
So, I just found out how to make it run in a different mode, and that still
didn't work. Even after uninstalled/reinstalled the game. I also went into
the Setup.exe and changed it to run compatibly with a different mode, and it
still didn't work. I'm at my wits end here...
>How can I need to upgrade? I've only had the PC for two months! I already
>have a NVidia GEForce 6800, and that's what the computer company said would
>be a good one to take. This is unreal. Well, thanks for all your help
>though. Any recommendations on what I should upgrade to?
There is something amiss on your system, the GeForce 6800 certainly
has enough video memory, run dxdiag.exe and paste the result here
please. Did you check for patches for the games and did you try to
install and run them in compatibility mode?
Katy P.
MS_MVP for Flight Simulator
Visit Project Magenta!
http://www.promagenta.com
Hi Katy-
I've taken screen shots of everything that came up after I ran DXDIAG. It
really didn't report any errors. The only thing that errored was on a
different game that I didn't install the DirectPlay option. Please send me
an email, and I'll send you the file with all the screen shots to you. I
can't past them in here, and I think things might go easier if you could see
exactly what I'm looking at too. liriel_nmf@yahoo.com
Thanks,
Nicole
> Katy P.
I noticed I forgot to answer you about the compatability mode. Yes I tried
to run it in compatability mode. That didn't work, and I also have a screen
shot of what pops up when I get the error. So, then I uninstalled the
program, then ran the setup wizard in compatability mode, then tried to run
the program in compatability mode, and I got the same error.
Also, I always get patches for my games off Adrenaline Vault. The company
that makes the games that I'm having trouble with was 3DO and New World
Computing, both of which are out of business. I'm beginning to wonder if
it's something in the programming of the games. Maybe it doesn't understand
what a gigabyte is? I'm kinda grasping at straws here...
"Liriel" wrote:
> Hi Katy-
> Thanks,
> Nicole
> > Katy P.
At the bottom on the dxdiag window there is a "save all info" button,
click on it then save the txt file and paste its content here, no need
to take screen shots ;-)
What are the games names?
Katy P.
OK, I'll do that tonight. The games are all Might and Magic's VI - VIII, and
Heroes of Might and Magic III. I haven't bought Might and Magic IX yet,
because I'm worried I'll spend the money and then surprise! it doesn't work
either you know? I'll paste in the text file tonight. Thanks again.
> Katy P.
In the meantime I have found these threads about Might and Magic on
ntcompatible.com:
http://www.ntcompatible.com/thread29553-1.html
http://www.ntcompatible.com/thread28237-1.html
This one looks promising as well:
http://celestialheavens.com/viewpage.php?id=383
As the games were not designed for XP and the publisher is out of
business, if you do not find a way to have them run under XP I'd
suggest going back to 9x for these - either with dual boot or on a
dedicated computer. I doubt that Windows 2000 will handle them any
better than XP...
Katy P.
OK, here you go. This is a huge paste, so here's half of it...
System Information
Time of this report: 3/18/2005, 17:33:53
Machine name: NICOLE
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack
2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Dimension 8400
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A03
Processor: Intel(R) Pentium(R) 4 CPU 3.40GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 263MB used, 3677MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: The registry information for the DirectPlay application
'Pool of Radiance 2' is missing or damaged. You should reinstall that
application.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6800
Manufacturer: NVIDIA
Chip type: GeForce 6800
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_00C1&SUBSYS_024510DE&REV_A2
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.6672 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/20/2004 15:09:00, 3721344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 9/20/2004 15:09:00, 2738592 bytes
Device Identifier: {D7B71E3E-4381-11CF-7E69-4F2203C2CB35}
Vendor ID: 0x10DE
Device ID: 0x00C1
SubSys ID: 0x024510DE
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1)
Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0)
DeinterlaceTech_BOBVerticalStretch
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0)
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Audigy 2 ZS Audio [DCC0]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_20061102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0445 (English)
WHQL Logo'd: Yes
Date and Size: 8/6/2004 10:43:26, 366384 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 192000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: Modem #0 Line Playback (emulated)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Emulated
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
Registry: OK
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
Description: Modem #0 Line Record (emulated)
Default Sound Capture: No
Default Voice Capture: No
Driver Name:
Driver Version:
Driver Attributes:
Date and Size:
Cap Flags: 0x20
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Audigy 2 ZS DirectMusic Synthesizer [DCC0], Hardware
(Kernel Mode), Output, DLS, Internal, Default Port
SB Audigy 2 ZS Audio [DCC0], Software (Kernel Mode),
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel
Mode), Output, No DLS, Internal
SB Audigy 2 ZS Synth A [DCC0] [Emulated], Hardware (Not
Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Sw Synth [DCC0] [Emulated], Hardware (Not
SB Audigy 2 ZS Synth B [DCC0] [Emulated], Hardware (Not
SB Audigy 2 ZS MIDI IO [DCC0] [Emulated], Hardware (Not
Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not
Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output,
DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x265A
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/10/2004 05:00:00, 4736 bytes
Gameport Devices
+ Intel(R) 82801 PCI Bridge - 244E
| Matching Device ID: pci\ven_8086&dev_244e
| Service: pci
| Driver: pci.sys, 8/3/2004 23:07:48, 68224 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7003&subsys_00401102
| | Service: gameenum
| | Driver: gameenum.sys, 8/3/2004 23:08:22, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/10/2004 05:00:00, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 22:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x413C, 0x3010
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/3/2004 22:58:34, 23040 bytes
| Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll
(5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll
(5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll
(5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll
(5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll
(5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll
(5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll
(5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll
(5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run,
Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Conexant D850 56K V.9x DFVc Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Baldur's Gate (DX7) - Registry: OK, ExeFile: BGMain.exe ()
Baldur's Gate2 (DX7) - Registry: OK, ExeFile: BGMain.exe (2.05.0000.0002)
Pool of Radiance 2 (DX7) - Registry: Error, ExeFile: ()
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 123.3 GB
Total Space: 147.8 GB
File System: NTFS
Model: ST3160023AS
Drive: D:
Model: SAMSUNG DVD-ROM SD-616E
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180
(English), 8/10/2004 05:00:00, 49536 bytes
Drive: E:
Model: PHILIPS DVD+-RW DVD8631
System Devices
Name: Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
Device ID: PCI\VEN_8086&DEV_266F&SUBSYS_01771028&REV_03\3&172E68DD&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English),
8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180
(English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English),
8/3/2004 22:59:44, 95360 bytes
Name: Intel(R) 82801FB/FBM SMBus Controller - 266A
Device ID: PCI\VEN_8086&DEV_266A&SUBSYS_01771028&REV_03\3&172E68DD&0&FB
Driver: n/a
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2662
Device ID: PCI\VEN_8086&DEV_2662&SUBSYS_00000000&REV_03\3&172E68DD&0&E1
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English),
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2660
Device ID: PCI\VEN_8086&DEV_2660&SUBSYS_00000000&REV_03\3&172E68DD&0&E0
Name: Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Device ID: PCI\VEN_8086&DEV_265C&SUBSYS_01771028&REV_03\3&172E68DD&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180
(English), 8/10/2004 05:00:00, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180
(English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004
00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English),
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English),
8/10/2004 05:00:00, 7168 bytes
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
Device ID: PCI\VEN_8086&DEV_265B&SUBSYS_01771028&REV_03\3&172E68DD&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180
(English), 8/3/2004 23:08:38, 20480 bytes
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
Device ID: PCI\VEN_8086&DEV_265A&SUBSYS_01771028&REV_03\3&172E68DD&0&EA
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
Device ID: PCI\VEN_8086&DEV_2659&SUBSYS_01771028&REV_03\3&172E68DD&0&E9
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
Device ID: PCI\VEN_8086&DEV_2658&SUBSYS_01771028&REV_03\3&172E68DD&0&E8
Name: Intel(R) 82801FR SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_2652&SUBSYS_01771028&REV_03\3&172E68DD&0&FA
Driver: C:\WINDOWS\system32\DRIVERS\iaStor.sys, 4.00.0000.6211 (English),
3/23/2004 12:13:58, 467200 bytes
Name: Intel(R) 82801FB LPC Interface Controller - 2640
Device ID: PCI\VEN_8086&DEV_2640&SUBSYS_00000000&REV_03\3&172E68DD&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English),
8/17/2001 13:58:02, 35840 bytes
Name: Intel(R) 925X PCI Express Root Port - 2585
Device ID: PCI\VEN_8086&DEV_2585&SUBSYS_00000000&REV_04\3&172E68DD&0&08
Name: Intel(R) 925X Memory Controller Hub - 2584
Device ID: PCI\VEN_8086&DEV_2584&SUBSYS_00000000&REV_04\3&172E68DD&0&00
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_D3\3&172E68DD&0&F0
Name: Conexant D850 56K V.9x DFVc Modem
Device ID: PCI\VEN_14F1&DEV_2F20&SUBSYS_200F14F1&REV_00\4&10416D21&0&08F0
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_CNXT.sys, 7.06.0000.0000
(English), 11/17/2003 15:58:02, 680704 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSFHWBS2.sys, 7.06.0000.0000
(English), 11/17/2003 15:59:20, 212224 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_DP.sys, 7.06.0000.0000 (English),
11/17/2003 15:56:26, 1042432 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0002.0002
(English), 4/9/2003 13:48:08, 11043 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\del200f.cty, 11/19/2003 02:15:00,
128398 bytes
Driver: C:\WINDOWS\system32\mdmxsdk.dll, 1.00.0002.0002 (English),
4/9/2003 14:01:32, 90112 bytes
Driver: C:\Program
Files\CONEXANT\CNXT_MODEM_PCI_VEN_14F1&DEV_2F20&SUBSYS_200F14F1\HXFSetup.exe,
2.01.0008.0000 (English), 10/30/2003 15:25:38, 532480 bytes
Driver: C:\WINDOWS\system32\HSFCI008.dll, 7.99.0099.0099 (English),
10/23/2003 15:01:36, 32218 bytes
Name: Broadcom NetXtreme 57xx Gigabit Controller
Device ID: PCI\VEN_14E4&DEV_1677&SUBSYS_01771028&REV_01\4&1D7EFF9E&0&00E0
Driver: C:\WINDOWS\system32\DRIVERS\b57xp32.sys, 7.73.0000.0000
(English), 5/29/2004 17:41:54, 186112 bytes
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00401102&REV_04\4&10416D21&0&11F0
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.2180
(English), 8/3/2004 23:08:22, 10624 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\4&10416D21&0&12F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180
(English), 8/3/2004 23:10:10, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180
(English), 8/3/2004 23:10:08, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180
(English), 8/10/2004 05:00:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180
(English), 8/10/2004 05:00:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000
(English), 8/17/2001 13:46:40, 6400 bytes
Name: Creative SB Audigy 2 ZS (WDM)
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_20061102&REV_04\4&10416D21&0&10F0
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English),
8/4/2004 00:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English),
8/4/2004 00:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English),
8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English),
8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180
(English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English),
8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English),
8/10/2004 05:00:00, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.0444
(English), 7/13/2004 10:09:32, 645360 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.0445
(English), 8/6/2004 10:43:26, 366384 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0443
(English), 7/13/2004 10:11:28, 178672 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.0443
(English), 7/13/2004 10:11:58, 6096 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0443
(English), 7/13/2004 10:12:36, 130288 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.0444
(English), 7/13/2004 10:13:14, 145488 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.0449
(English), 8/12/2004 15:40:50, 904752 bytes
Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.0444
(English), 7/13/2004 10:15:48, 148432 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0006
(English), 8/6/2004 17:29:14, 6656 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 11/26/2003 12:29:54, 127226 bytes
Driver: C:\WINDOWS\system32\ctdaught.dat, 8/3/2004 16:54:46, 53932 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English),
11/13/2003 17:54:38, 65536 bytes
Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.0441 (English),
11/13/2003 18:02:14, 114688 bytes
Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.0443 (English),
7/13/2004 09:53:14, 585728 bytes
Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.0441 (English),
11/13/2003 18:04:08, 606208 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English),
8/17/2001 14:35:46, 36864 bytes
Driver: C:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 12:42:28, 7406 bytes
Driver: C:\WINDOWS\system32\Audigy.bmp, 11/13/2001 09:48:20, 1912 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0416
(English), 11/12/2003 20:11:54, 333600 bytes
Driver: C:\WINDOWS\system32\ctbas2w.dat, 8/12/2004 15:52:44, 140643 bytes
Driver: C:\WINDOWS\system32\ctsbas2w.dat, 8/12/2004 15:52:38, 264466 bytes
Name: NVIDIA GeForce 6800
Device ID: PCI\VEN_10DE&DEV_00C1&SUBSYS_024510DE&REV_A2\4&16EC1A1&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.6672
(English), 9/20/2004 15:09:00, 2738592 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.6672 (English),
9/20/2004 15:09:00, 127043 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0015 (English),
9/20/2004 15:09:00, 32256 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0015 (English),
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.6672 (English),
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.6672 (English),
9/20/2004 15:09:00, 5267456 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.6672 (English),
9/20/2004 15:09:00, 4583424 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.6672 (English),
9/20/2004 15:09:00, 86016 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 9/20/2004 15:09:00, 157490 bytes
> ntcompatible.com:
> better than XP...
> Katy P.
Thanks again for all your help. I'll check out those threads that you posted
earlier. Here's the second half of it.
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 266240
bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 27136
bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/10/2004 05:00:00 10496
bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 1179648
bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 8192
bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 1689088
bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/10/2004 05:00:00 436224
bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 825344
bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/10/2004 05:00:00 590336
bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/10/2004 05:00:00 350208
bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/10/2004 05:00:00 47616
bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/10/2004 05:00:00 34816
bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/10/2004 05:00:00 33040
bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 229888
bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 23552
bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/10/2004 05:00:00 42768
bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 57344
bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 30208
bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 18432
bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 375296
bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 3584
bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 3584
bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 212480
bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 83456
bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 116736
bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 21504
bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 35328
bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 60928
bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/10/2004 05:00:00 53520
bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 159232
bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 181760
bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/10/2004 05:00:00 44032
bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/10/2004 05:00:00 394240
bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 68608
bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/10/2004 05:00:00 76800
bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 35328
bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:08:22 10624
bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 367616
bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 1294336
bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 19456
bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 181760
bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 71680
bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 104448
bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 28672
bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 61440
bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 181248
bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 35840
bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 105984
bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 103424
bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 82432
bytes
system.dll: 1.00.3705.6018 English Final Retail 8/19/2004 16:03:52 1179648
bytes
system.dll: 1.01.4322.2032 English Final Retail 12/20/2004 17:40:58
1224704 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 619008
bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 1227264
bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 2113536
bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/10/2004 05:00:00 924432
bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/10/2004 05:00:00 1028096
bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/10/2004 05:00:00 22528
bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 70656
bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 59904
bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/10/2004 05:00:00 498205
bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 35328
bytes
mpg2splt.ax: 6.05.2700.2230 English Final Retail 9/28/2004 01:54:48 149504
bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 14336
bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 20480
bytes
qasf.dll: 10.00.0000.3646 English Final Retail 8/10/2004 05:00:00 221184
bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 192512
bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 279040
bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 385024
bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 562176
bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 733696
bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 1287680
bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/10/2004 05:00:00 246302
bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/10/2004 05:00:00 199680
bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/10/2004 05:00:00 848384
bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/10/2004 05:00:00 120320
bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/10/2004 05:00:00 338432
bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/10/2004 05:00:00
755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/10/2004 05:00:00 200192
bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/10/2004 05:00:00 183808
bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/10/2004 05:00:00 154624
bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/10/2004 05:00:00 204288
bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928
bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048
bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640
bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 4352 bytes
mpeg2data.ax: 6.05.2700.2230 English Final Retail 9/28/2004 01:54:48 62976
bytes
msvidctl.dll: 6.05.2700.2230 English Final Retail 9/28/2004 01:54:48 1616384
bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 30720
bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 17408
bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/10/2004 05:00:00 50688
bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Sonic Scaler,0x00200000,1,1,SonicDSScaler.ax,1.00.0000.0001
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Sonic TimeStampSmoother Filter,0x00000000,0,0,,
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,2.01.0001.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
WAV Dest Trial,0x00200000,0,0,WavD2Try.dll,1.01.0000.3463
CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0000.0003
MainConcept (Sonic) DV Video
Decoder,0x00600000,1,1,sonicmcdsdv.ax,2.01.0000.0004
Encoder,0x00200000,1,1,sonicmcdsdv.ax,2.01.0000.0004
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.00.0003.0000
WST Renderer,0x00800000,1,1,WSTRenderer.ax,6.05.2700.2230
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,3.00.0000.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,3.00.0000.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
BPM Metadata,0x001fffff,1,1,MetaBPM.ax,1.00.0004.0000
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Sonic Audio Depth Converter
(Symphony),0x00200000,1,1,AudioDepthConverterS.ax,5.00.0000.0001
Indeo® video 5.10 Compression
Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Musicmatch Radio Source,0x00400000,0,1,MMRadioDSFilter.ax,8.20.0003.0074
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
Creative Still Picture MPEG1 Splitter,0x00600000,1,2,CTspf.ax,1.00.0003.0000
Photo Story 2 Trial Source Filter,0x00200000,0,1,PSSF2Try.dll,1.01.0000.3463
Sonic DirectShow Tap,0x00200000,1,1,DirectShowTap.ax,1.00.0000.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2700.2230
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.02.0000.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2700.2230
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Decompression
Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0006.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
VBI Codec,0x00600000,1,4,VBICodec.ax,6.05.2700.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2700.2230
Sonic MPEG Audio Decoder,0x00200000,1,1,SonicMPEGAudio.DLL,2.05.0004.1406
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
RTStreamSink,0x00200000,1,0,RTStreamSink.ax,1.00.0000.0000
WMS Filter,0x00400000,0,1,CTWMSFLT.DLL,1.12.0001.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Sonic RTStreamSink (Symphony),0x00200000,1,0,RTStreamSinkS.ax,5.00.0000.0001
Sonic Field Switch,0x00200000,1,1,FieldSwitch.ax,1.00.0000.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2180
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Sonic RT Stream Source
Filter,0x00400000,0,1,RTStreamSourceFilter.ax,1.03.0000.0001
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,5.00.0000.0000
Sonic DVD LPCM Converter,0x00600000,1,1,DVDLPCMConverter.ax,1.00.0000.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0000.0004
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,3.00.0000.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0000.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2700.2230
Sonic Audio Depth
Converter,0x00200000,1,1,AudioDepthConverter.ax,1.00.0000.0000
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
Sonic MPEG Non-Pro Audio Decoder
(Symphony),0x00200000,1,1,SonicMPEGAudioS.DLL,2.05.0004.1403
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,3.00.0001.0000
MainConcept (Sonic) MPEG
Encoder,0x00200000,2,1,SonicMCESMpeg.ax,1.00.0001.0023
MainConcept (Sonic) MPEG Video
Encoder,0x00200000,1,1,sonicmcevmpeg.ax,1.00.0000.0014
MainConcept (Sonic) MPEG Audio
Encoder,0x00200000,1,1,sonicmceampeg.ax,1.00.0000.0007
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0000.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
CBVA Filter,0x00200000,1,1,CBVAFilter.dll,5.01.2700.2180
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,3.00.0001.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Sonic MPEG Video Decoder
(Symphony),0x00200000,2,1,SonicMPEGVideoS.DLL,2.05.0004.1041
MainConcept (Sonic) Sample Buffer
Filter,0x00200000,1,1,SonicMCSampleBuffer.ax,1.00.0000.0004
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
Sonic MPEG Video Decoder,0x00200000,2,1,SonicMPEGVideo.DLL,2.05.0004.1044
Sonic Audio SRC,0x00200000,1,1,DSAudioSRC.ax,1.00.0000.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Sonic Audio Offset Filter,0x00200000,1,1,Offset.ax,
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0000.0002
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
..RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
WST Pager,0x00800000,1,1,WSTPager.ax,6.05.2700.2180
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2700.2230
Sonic Rainbow Fix,0x00200000,1,1,SonicRainbowFix.ax,1.00.0000.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Creative MP3 Source Filter,0x00400000,0,1,CTMP3SFT.DLL,1.00.0010.0000
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0000.0002
Sonic File Writer,0x00200000,1,0,SonicFileWriter.ax,
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,3.00.0003.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.05.2700.2230
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2700.2230
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.00.0003.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Uncompressed Domain Shot Detection
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Sonic Cinemaster MPEG Splitter
(Symphony),0x00200000,1,2,SonicMPEGSplitterS.dll,1.00.0000.0103
NVF Filter,0x00400000,0,1,CTNVFFLT.DLL,1.00.0000.0000
CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.4418
CyberLink Video/SP Decoder DELL 5.3,0x00600000,2,3,CLVSD.ax,6.00.0000.0818
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.1305
CyberLink TimeStretch Filter,0x00200000,1,1,clauts.ax,1.00.0000.1305
CyberLink Audio Effect,0x00200000,1,1,CLAudFx.ax,5.00.0000.1305
CyberLink DVD Navigator,0x00600000,0,3,CLNavX.ax,5.03.0000.0803
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,6.00.0000.0727
DirectShow Tap (Symphony),0x00200000,1,1,DirectShowTapS.ax,5.00.0000.0001
Sonic MPEG Splitter,0x00200000,1,2,SonicMPEGSplitter.dll,1.00.0000.0105
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Sonic DV Scene Detector,0x00600000,1,1,DVSceneDetector.ax,1.00.0000.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0001.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Sonic Video Performance
Monitor,0x00600000,1,1,VidPerfMonitor.ax,1.00.0000.0000
Sonic SP Video Renderer,0x00200000,1,0,SonicVideoRenderer.ax,8.01.0000.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
SB Audigy 2 ZS Audio [DCC0],0x00200000,0,0,qcap.dll,6.05.2600.2180
Modem #0 Line Record,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy 2 ZS MIDI IO [DCC0],0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy 2 ZS Sw Synth [DCC0],0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy 2 ZS Synth A [DCC0],0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy 2 ZS Synth B [DCC0],0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
SB Audigy 2 ZS MIDI IO [DCC0],0x00200000,2,2,,5.03.2600.2180
SB Audigy 2 ZS Audio [DCC0],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB Audigy 2 ZS DirectMusic Synthesizer [DCC0],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Sw Synth [DCC0],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Synth A [DCC0],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Synth B [DCC0],0x00200000,1,1,,5.03.2600.2180
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.05.2700.2230
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2700.2230
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2700.2230
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2700.2230
Audio Renderers:
SB Audigy 2 ZS Audio [DCC0],0x00200000,1,0,quartz.dll,6.05.2600.2180
CyberLink Audio Renderer,0x00200000,1,0,cladr.ax,6.00.0000.0818
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Modem #0 Line Playback
(emulated),0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: SB Audigy 2 ZS Audio
Modem #0 Line Playback,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
SB Audigy 2 ZS Synth A [DCC0],0x00200000,11,2,,5.03.2600.2180
SB Audigy 2 ZS Audio [DCC0],0x00200000,13,2,,5.03.2600.2180
> ntcompatible.com:
> better than XP...
> Katy P.
Hi Katy-
I tried those threads, and none of them worked. Any ideas based on my
DXDiag info?
> ntcompatible.com:
> better than XP...
> Katy P.
