Quote:
"Serial ATA offers more robust cabling and a higher interface bandwidth (150 or 300 MB/s as opposed to 100 MB/s with UltraATA/100)."
Question:
Do americans, or wherever the reviewer lives, have different cables than we europeans? Cause I can't recall a time where pata cables were as unreliable as sata. When switching hardware often or moving the computers often, one will notice that sometimes sata drives don't work afterwards. Because those damned cables don't have any clip or other feature to mount them securely. I know that some highend cables like those that came with my ga-p35-ds4 have clips now, but none of the sata drivers I've seen support those, and I am yet to see a power supply with a similar clip on the power cable. I've switched all my sata power cables for regular molex, cause they don't fall out again. Also the molex ones aren't as fragile. It is VERY easy to break a sata power plug if you were to pull the cable up or down (as opposed to directly back), which happends often if you're using more than one drive in a cramped chassis and want to hide the cables. For instance the antec sonata 3 or similar.
In short, I haven't EVER seen a sata cable that is more robust than their predecessor. Are they different in the us?
