Recently my motherboard decided it wanted to fry itself and I had to order a new one. I settled on the motherboard in the post name from NewEgg. The first one I ordered would not post at all, so I had to send that back for an RMA. The second one I got seemed to work fine, everything posted alright so I started hooking up the other components. I hooked my ata-100 hard drive up to the primary IDE channel and my ata cd burner to the secondary channel, both on cable select. When I then tried to boot the system it recognized the hard drive but not the burner. I swapped them around and the situation reversed, recognized the burner but not the hard drive. This leads me to believe that the second channel is dead. I tried setting up hard drive and cd burner as a master and slave unit on the primary IDE channel and that worked, sorta. The hard drive would only run as an ata-33 drive, and only as the slave. I swapped around the jumpers for designating as master and slave in several combinations but no help. I decided to go ahead and install Windows with that setup anyway. Everything worked fine, OS installed properly and I got into Windows where I encountered the second problem. The OS and come to think of it, the BIOS did not find my onboard network adapter. I installed the nForce driver pack from their webpage and it still did nopt recognize it. When I plug a network cable from my modem to the port it lights up but the computer does not seem to see it. These are the only two problems I seem to have with the motherboard, but before I send it out for an RMA I'd like to find out if it could be something else. I thought it could have been the power supply not cutting it anymore but I am not sure. I'll list my system components below and hopefully someone can give me some insight.
(WFWOS) = Worked fine with old system.
Athlon XP 3200 Barton (New)
EP-8RDA3I Revision 3.x
2x256 PC 3200 Kingston RAM (WFWOS)
ATI Radeon PRO 9800 (WFWOS)
WDC Special Edition 80gb 8mb buffer ATA-100 (WFWOS)
TDK CD-RW 48x (WFWOS)
330 watt power supply
A link to where I bought the motherboard is right below.
http://www.newegg.com/app/viewproductdesc.asp?DEPA=0&description=13-123-208&ATT=Motherboards+AMD&CMP=OTC-pr1c3grabb3r
