Error 0251 System CMOS checksum bad: how do I fix it?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi, Some help would be appreciated please. Every now and again my computer
starts up with a "bleep bleep" then appears a black screen with writing on.
It always says "0251:Stystem CMOS Checksum Bad- Default Configuration used".
I have tried going further and looking into it, but it scares me, in case I
make a mess of it all. So now every time it happens I just press "F2" which
starts up the computer anyway.. I believe I am just by passing the problem
ever time and would love to sort it out. Can any one tell me which buttons to
press once onto the page and get rid of the problem once and for all... Thank
you in advance
Magzy99
Hi
Please see if the following helps:
http://groups-beta.google.com/groups?q=0251:System+CMOS+Checksum+Bad-+Default+Configuration+used&
Will Denny
MS-MVP Windows Shell/User
Please reply to the News Groups
"Magzy99" <Magzy99@discussions.microsoft.com> wrote in message
news:A815A064-FD35-4037-913D-52AE7DBB1F94@microsoft.com...
> on.
> used".
> I
> which
> to
> Thank
> you in advance
> Magzy99
hi
go for checking the CMOS(complementry metal oxide semi conductor) 's battery its the general problem of above mentioned error your cmos battery may be running out of the power........
that was all........ i mean as far as i know........ bcoz i was having th same problem..
You realize you are replying to a post that is almost 6 years old?
