EVGA GTX 680 FTW 4GB power help
kkullar
6
Hey Everyone,
I recently brought a 680 gtx evga ftw edition 4gb, this may sound a bit noobish of me but when i came to install the power, the card has an 8 pin slot and a 6 pin slot, do i have to fill both? I have a 6-pin coming out of my power supply but its got a small 2-pin connected to it would this work as the 8 pin and could i just use the adapter they send me to convert 2, 4 pins into a 6 pin? would that configuration work?
Thanks
Ok here is the problem, i just tired to put the 6+2 into the 8 pin slot and the 6 goes in fine but the + pin doesn't go in, on the box it says a 6 pin and a 6 pin will do fine, also the 8 pin adapter requires a 2 6 pins which i dont have, it seems to boot fine with 2 6pins but should i maybe get a bigger power supply for the future? i have 750 w at the moment?
I think i set up the wrong sort of thread for that, i have no option to do it, ill make sure i do it like that next time :)
