S230HL acer monitor. using VGA (lcd with led technology or sumthin)
I bought it, i came home, plugged in power adapter, there was this pink hue and waves going down in the right side https://streamable.com/oh3u7 (its almost unnoticiable in white, very noticable in black and dark colors)
https://ibb.co/1XKZ6yt - picture of problem
Few days later, i contacted seller, checked it very carefully. got it replaced ,changed its power adapter. 3 days it worked perfectly normal. but yesterday exactly same problem with pink hue came back randomly when i was watching a video. (i though i was having a bad dream about the old monitor with problems)
If i look closely the pixels seem to be displaying correct color but the pixels are surrounded by pink lines, and the affected area i can see waves going down.https://gyazo.com/de005239105d7e92034dd831bb93c61d
The rest of the screen got a bit blurry when something is moving on screen.
I've made a post like this before but this is the most detailed one, so i hope someone can give me an idea on what the problem could be caused by. I wanna try everything that could fix the issue
What i've tried:
Tried a different VGA cable
Unplugging VGA cable, then holding power button to reset monitor.
Applying some pressure
Connecting power thingy to the wall
Thinkering a lot with the video cable
So VGA can't be a problem because the problem is still there without connection, or is it possible for bad/old vga cable to permanantly cause monitor defect?
even though its not cable problem could getting DVI to VGA cable magically fix it?
im feel really anxious and hopeless over the last few days idk what to do exactly
What i've tried:
