explorer wont load after networking wizard and reboot
Mike
Splendid
Apr 1, 2004
3,865
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
xp pro, wireless broadband, still works. just wanting to share folders
between 2 wireless pcs. after login, wallpaper appears and thats it! i can
run programs via task manager, but trying explorer.exe brings the desktop
then dissappears. any ideas? thanks in advanced.
Taskbar Repair Tool Plus!:
http://www.kellys-korner-xp.com/taskbarplus!.htm
Mark L. Ferguson
FAQ for Windows Antispy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
"mike" <mike@discussions.microsoft.com> wrote in message news😀B7A8CCA-75DD-41E4-9D0F-E9D4BFFFBCE2@microsoft.com...
thanks for the reply. unfortunately did not work. anything else? thanks again.
mike
> Mark L. Ferguson
To repair all system files, go to Start/Run, and type (or paste in): SFC /SCANNOW
If no help, try a Repair, or 'upgrade' setup.
If you run an XP "Upgrade"setup, from the original, or "Gold" version of the setup CD, and you have SP2 installed, it might go into
a setup loop, and you could lose your install. Uninstall SP2, BEFORE you Upgrade setup from CD (that lacks sp2 on it.)
875350 - How to remove Windows XP Service Pack 2 from your computer: http://support.microsoft.com/default.aspx?kbid=875350 How to
Perform a Windows XP Repair Install: http://michaelstevenstech.com/XPrepairinstall.htm
Mark L. Ferguson
"mike" <mike@discussions.microsoft.com> wrote in message news:BB932C4E-EBED-43BC-9908-5DC1429AF3D0@microsoft.com...
> mike
>> Mark L. Ferguson
