pnightshade :
What did you use to achieve the 100psi mark and how did you measure the force?
I'm going from past experience from the Thermal Compound Roundup regarding a certain Thermal Compound (IC Diamond) that the representative refused to enter a test sample because their product required agreeing to a confirmed 50psi clamping pressure.
I did not have a problem going through all their requirements to submit a testing sample and giving their product 50psi of clamping pressure, and clamping pressure paper would be provided by them, and sent to a laboratory for test results at their expense for me to know the exact clamping pressure I was using.
The reason he refused to submit a testing sample was I informed him all the other TIMS would be tested at that same clamping pressure to be fair across the board.
The product representative knew some of the other TIMs would out perform theirs at that same 50psi clamping pressure, so he simply refused to enter a testing sample.
I was basically forbidden to discuss any of this regarding their product in the Thermal Compound Roundup itself, and did not even mention IC Diamond at all, but I can say whatever I want regarding IC Diamond in this thread.
The representative did not know I already had a tube of IC Diamond 24 in my possession.
I experimented with IC Diamond clamping pressure on my own, matching the pressure footprint results shown online at their website against my own testing and discovered 50psi spread results could be mimicked maxing the spring tension on the TRUE.
I've said approximately 100psi not actual, without some pressure clamping paper, I'm just estimating comparing standard know clamping pressure of 35psi that most heat sinks clamp by, and the learned comparison of the IC Diamond experience.
The Thermalright Ultra Extreme was know for being fully clamped down maxing the springs you could get approximately 50psi, and my comparative testing confirmed that, so I'm using that experience as a comparison.
I'm presently not using any springs and have just a measuring gauge to measure the gap between the base and clamp arms. I tightened as far as I could with finger pressure which would have easily given a 50psi + pressure, then continued with a pair of pliers.
Each of the 4 arms is equally tightened 1/16th or 1.5mm tighter than maximum finger tightening pressure.
So I'm just guessing at 100psi it could be + or - 10psi to 20psi in all actuality, but it is way past standard clamping pressure.
From online researching others clamping pressure used some claimed as high as 150psi to 200psi could be used, but I was afraid of damaging the peltier and there wasn't a clear answer to go with online so I approximated 100psi would be safe and so far it has been.
I understand not everyone has a Thermal Roundup experience under their belt so actual clamping pressure could turn out to be something to be experimented with.
Unless of course they want to go the pressure paper route, send it to a lab for testing, and sit around waiting for the results to to come back, to continue.
Otherwise there's no actual solid means to test it, but if the online consensus is correct the peltier can take much more than it looks like it can take anyway.
So even though I'm estimating 100psi, I'm apparently OK, as the present performance shows.
And for the record at 35psi standard heat sink clamping pressure, IC Diamond performed exactly the same as Artic Silver 5 and those results were under water and air cooling testing, you can check the Thermal Compound Roundup results in my sig to see what Artic Silver 5s performance results were.
