4745454b :
It is was I was looking for. Mostly. I know doing either of these would be a "cool" thing to do. What I'm wondering is if the TEC or jugs is the way to go. Or, if you had to do it over again which would you setup? I like the TEC because of not needing to change jugs. But not everyone can mod the waterblock or change the wires on the PSU...
One thing about experimentation, someone has to do it!
From the very beginning of this thread it has been all about getting more cooling performance than traditional air or water cooling was delivering.
I never had intentions of trying to disrespect the water cooling community, I was just overclocking and not getting the results I wanted and started searching for a better performing cooling solution.
If I knew then, what I know now, it would have been different, of course I've been saying that my entire life.
I had already spent chunks of money on the best of the best air coolers, and water cooling closed loops, and still was not getting the cooling I wanted.
So since I already had on hand what I needed, from all the money I had wasted, ice jug cooling turned out to be exactly what I needed at the time.
So there's been a lot of learning the hard way!
4745454b :
Knowing what I know now, absolutely the TEC!
4745454b :
Affirmative!
4745454b :
You don't have to mod a water block, I did not know that at the time, you can buy water blocks specifically designed to channel the water through the block, keeping the water in the block longer to pickup the cold from the TEC.
These water blocks are CNC milled and the website has a large inventory of various size water blocks, so pretty much any TEC size that someone chooses, they have a channeling water block for it.
http://www.shop.customthermoelectri...CF605C6978D8390276F418783DF623EE.qscstrfrnt03
I've ordered the one below to replace my modded water block.
http://www.shop.customthermoelectri...F34857385B77C9B135C34CCB785A69D3.qscstrfrnt03
Regarding power supply modding:
The website below has just about any power supply available to run any size TEC, with very reasonable prices.
http://www.jameco.com/webapp/wcs/st...CategoryName=AC-to-DC Switching&category=4540
The power supply below would have been my choice had I not adapted my Silverstone OP-1000w to do the job. The Silverstone however no matter how amperage capable it is can only deliver 12v to my 15v spec'd TEC, meaning what cooling performance increase would be added if the TEC got the extra 3v?
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2105172_-1
I may pick this power supply up later?
But, I'm hoping that the water block itself is going to increase the cooling, by channeling the water, it's definitely got to work better than what I'm presently running.
My goal from this point is to be able to run the entire loop adding the 2 GPUs back into the equation.
4745454b :
So continuing to answer that question, I am definitely pursuing the TEC cooling route, because I literally am doing it over again.
It would be nice if I could drop the reservoir size down to the size of a standard dual bay res, and gut my RadBox of the radiators to house the entire TEC assembly.
The first tests will be to see how the new water block affects the water temperature in the cooler?
So the experimenting continues! Ryan
