Lawrence Orsini :
Hi guys,
I have another interesting way to get some pretty low and stable temps without overheating the office. I call it the commode cooler. Basically I built a heat exchanger for the toilet tank, run a couple hoses from a 10 gallon thermal bank I use to capture the waste heat from my rig (I don't like blowing all that stuff into the office, better to store it and use it for good purpose later) and, when I don't have good use for the wast heat I'm storing, I give the heat a 'flush'.
Its surprisingly effective. I've dropped 40F off the loop in 10-15 min with 2 or 3 'flushes' (keep in mind the toilet is plumbed with cold water) and typically use it to unload the thermal bank in the evenings just before I shut down for the night so it is cool and ready to store heat in the morning when I fire up the computer. The thermal bank is about 10 gallons of water, just about the best thing out there for storing thermal energy, plumbed to my loop with quick disconnects. I have an after cooler (a couple old thermaltake rads sandwiched between 3 Noctua fans) at the end of the loop that are set on a curve that keeps them off or idle until the loop reaches about 140F and then they ramp hard to full speed at 145F. This is more of a safety measure, I've never exceeded the capacity of the thermal bank in a day unless I was stress testing or folding. (I did leave the system folding for 10 hours and came back to an office that was 95 ambient with the bank and loop sitting at 150F and the after cooler lazily cycling that fan curve between 140 and 145F)
So, the great thing about having the thermal bank and commode cooler is, no fans, no heat and I have a rig that can loaf at 80F in the loop all day or go all out (3EVGA 670 FTW/FX 8350/NB/memory pulling about 750w at full load - all under water) clocked to the extreme for about 3 hours folding, (the GPUs easily hit 180F overvolted and OCd) hit the flush at about 140F loop temp 2 or 3 times in 15 min and be back to 80-90F in the loop and bank. If I time it right, theres usually a reason to flush... if you know what I mean.
Food for thought - I don't know what a peltier cooler costs but its probably more than a flush or two of the john... and sounds like less effort than lugging frozen jugs back and forth yo your cooler.
Laz
I'm going to address your food for thought, looking at all your brass fittings, copper tubing, and the rest of your setup investment you could have gone the TEC cooling route?
The purpose of below ambient is to have a higher stable overclock and run your CPU cooler for longevity, having your GPUs reach 180f, ever!, with custom cooling, is not good it's bad, 180f is higher than the stock air cooler would have allowed.
**the way my loop is designed, with an aftercooler just ahead of the CPU in the loop, the CPU never reaches 180F - It regularly runs up to and stays at 150 under load. The GPU will run up 180F OCd if the bank is about 150/160F - thats not a bad delta across the EK blocks and this is a good thing for me because I'm trying to build heat quickly on this prototype.
My 2 580GTX on their stock coolers ran an 80c load temperature or 176f, on the radiator cooling the load temperature dropped to 40c or 104f and never went above that, and you have your CPU tied into that same loop?
**The CPU is on the same loop, it has a cooler that keeps it right between 145/150F max. This is on purpose and by design. If I wanted to run below ambient or was interested in keeping the thing cool instead of hot, I'd reconfigure a bit. Heck, you've piqued my interest now... I might do some mods and see how cool it'll run.
When I first saw your concept I assumed you were using the toilet tank as a below ambient room temperature cooling source, that's my bad I should have thoroughly read your first post!
My peltier cooling does cost more than the flush of a john, but so does your setup, brass fittings and copper tubing is not given away it's expensive, so duplicating your setup cost way more than a flush of a toilet.
**Yep, not really worried about the cost, if I were taking the thing to production I'd use a cheap copper/aluminum radiator or a slightly more expensive (25$) flat plate cooler on ebay and dump it in the tank. Not trying to compete in some cost/cooler war here, this was just a fun evening distraction.
I asked you earlier if 109.4f or 43c was your CPU idle or load temperature, my present CPU Idle temperature (Cores Averaged) is 18.4c or 64.4f at a 4500mhz overclock, my CPU load temperature is 33c or 91.4f and that's with a 23c ambient room temperature or 73.4f and water temperature of 14.9c or 58f.
So if 109.4f or 43c is your CPU load temperature in that picture, that's not to shabby, but if it's your CPU idle temperature?
**It was idle, I'll run a loaded temp if you really want to see the graphs, again... I'm really not looking for bragging rights here, I came across your thread looking for some OC software and thought I'd aid the cause.
Well you do the math.
I'm not really interested in the cooling math, I'm interested in the heating math!
