Going for this cooler/chiller box,
http://www.ebay.co.uk/itm/170853458552?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
28L is a nice volume I think
(in addition to the two loops own volume, mine is about 6L atm but the added tubing length to the chiller will add about a litre or two I guesstimate)
plan is to drill ports through from the top,
grommet and seal the lines, which will both be under the level of liquid in there for noise control
the tubes from the chiller will have Qdc's to each Pc to allow independant use or removal if required
the chiller can be left on 24/7 if its mainspowered (It has an Eco-mode apparently
😛), moving water doesn't stagnate,
I could hook it up to a Pc so it came on when the Pc did but theres no point/benefit
her loop woll follow roughly the same lines as mine, (no radbox though)
as in it can be disconnected and fed back into itself so the choice is hers to run it standalone or hooked up to the chiller,
again in case its been missed,
the Pc's loop in its own right will be capable of dealing with the heat produced,
the chillerbox will just provide cooler water and much greater volume
I will throw some coils into the chiller as well, maybe a cathode if its needed
it will be a while away yet as the garden needs sorting first, then the kitchen and then second room, but that just gives me time to plan, design and purchase the bits
Moto
