Motopsychojdn :
The chiller I'll be using is a mains powered unit, so it will have something working to keep things cold, it may just be some fan arrangement, but more likely a compressor with a gas in tubes, I won't know for sure till I've bought it,
But yes, you could just have a 'bucket' with ice in, thats essentially how Ryans scheme worked, loop water ran into the container and he managed temps by dumping frozen jugs in
Moto
You make my project sound in the past tense Moto, This wasn't a fluke experiment, I'm using this cooling right now, and each and every day!
My reservoir is a cooler or ice chest, and I don't dump the ice in it or it would splash all over the place, I gently place them inside the cooler, and I don't even put ice in until the water temperature is above 15c.
The cooler itself is insulated and designed to keep ice as cool as possible for as long as possible, sometimes I think THGF users think I'm constantly running to the freezer to swap out ice every hour on the hour, and that's not the case.
At this very minute my actual water temperature is 14.1c, what is your water temperature right now?
My CPU is idling at 17c what's your CPU idle right now?
At the most I'll use 2 jugs in and entire day of full computer use (Gaming), other days I only use one jug (Surfing the net and posting at Toms), and there's been days with low temps at night that I put in a jug before shutting down and don't use one at all the next day, because by the morning my temperature in the cooler has dropped to about 8c.
The largest inconvenience is the jugs will only last freezing and thawing about 10 times, then they have to be replaced but very rarely has 2 ever failed the same day, and I keep fresh jugs of distilled water on hand just for that.
When the jug fails I siphon off a gallon from the cooler and pour the leaking jugs distilled water in the cooler, so actually my water in the cooler is being refreshed on a regular basis.
I'd venture to say, the water I'm running in my setup is probably in better condition than what's in your closed loop.
