Okay so When I connect my Hardisk , For the first 10-20 seconds I'm able to view the files inside, After few seconds it completely freezes , Infinite Not responding , Cannot view files/View properties All system operations are stuck untill I pull out the usb cable from my laptop . If I try opening task manager (while system is on freeze) it does not open, I could not eject the Hardisk from Laptop , No application can be opened during this time , when I manually disconnect it all system or apps pop up suddenly, Meaning the Hardisk makes my entire pc stuck .. When I run chkdsk on CMD it's also stuck , Resumes only after I disconnect the Hardisk .. IF I plug in again IT works for few seconds and again FREEZES I do not want to lose data ( it's still Under warranty: Seagate Backup Plus 1 TB HDD, Their Recovery cost hundreds of dollars, Can't afford that high) I've tried it on different pc and cables .. This problem occurred all of a sudden .. I just need few important files from that hardrive , Is there a way I can recover/fix it ?? Thank you !
