Archived from groups: rec.video.desktop (More info?)
Hello. I've just bought a WD 250GB usb/firewire external hard drive, mainly
for video editing and the files involved are really large. But I'm having a
problem with it.
Now the usb connection seems to work ok. I can capture video to the drive
and edit it, then save the rendered file. . But I've heard that the firewire
connection is meant to be more reliable and faster when dealing with hard
drives so I'd prefer to use this. However it doesn't work. When I connect it
through firewire it starts off okay, but when I start transferring files to
the drive, after a couple minutes it disappears from Windows and I get a
Delayed Write Failed message. I think this happens because the connection to
the drive has stopped. The drive is no longer recognized in My
Computer/Device Manager/Disk Management. It has gone west! This happens
EVERY time. I then unplug the cable from the drive/computer, reconnect and
it appears again with no conflicts but disappears after a few mins when I
try to use the drive with a delayed write error.
This only happens when I connect through firewire. It hasn't happened when
I've used the USB.
I've has the firewire card for 10months and have used it to transfer dv from
my camera with no problems.
Has anyone experienced something like this and if so what could be the
solution to get the firewire to work? I don't think the disk is faulty as it
works with the USB. The card has 3 firewire ports and I get the same problem
with all of them
problem with it.
I've used the USB.
with all of them
