I'm struggling to understand the right way to set up these fans so that the ST120RGB's be controlled by L-Connect via the Galahad II
I have 7 individual ST120's, as well as the fans on the AIO radiator. So that's 8 sets of 2 cables. One cable is RGB, the other is for the fan header.
6 of those fans were in 3 packs so came with 2 sata powered fan hubs (that fit 6 fans each).
Is it as simple as daisychaining both cables from all 7 fans, and the radiator, connecting them to the splitter cable (from the AIO) and into the AIO pump?
Does that let me use L-Connect on all fans? (Manual is unclear, it says "connect ARGB device", but this may just be to allow connection of the AIO fans. Or a single device, not 8 daisychained).
And if I do that, would the AIO have sata power enough to power all the fans, or should I include the sata powered hub from the ST120 3 pack somewhere in the daisychain to provide extra power?
Would having sata power twice in the daisychain cause problems?
I'm so confused! Please help
