Hello,
Case NZXT H710i
I have just built my first PC, and for the most part, I am an idiot, as the name suggests.
When the case arrived the 4 NZXT fans were pre installed. 3 in the front and one rear exhaust.
I believe:
The 3 fans at the front were already connected to the came.
Each connection to the cam was a 'daisy chain' cable.
I had bought 3 additional fans - ll120 Corsair fans.
I had connected the RGB cables into the node as per instructions, and then, instead of installing each fan into a header on the board (Asus Crosshair Hero VIII) which would cause hassle with cable routing ect, I utilised the the daisy chains ( each daisy chain only had one 4 pin, the others had the 3rd pin missing).
I also plugged the rear fan into one of these daisy chains.
RGB on the corsairs work and all 4 (the one rear exhaust NZXT fan and the 3 corsair fans) spin.
But they do not appear in the CAM software.
Questions:
Should they show in the CAM software.
Have I connected this all up correctly.
How do I adjust fan speed.
Thanks in advance.
Case NZXT H710i
I believe:
Questions:
Thanks in advance.
