Hi everybody,
I have a question about the fan controller of this case
which I do not know how to connect. Here are some pictures:
There are four fans. Each one is conncted to the controller via one of the four connectors on the right, the fan cable continues beyond the fan controller and at the end there is this 3 pin connector (one for each fan, I will call them F1, F2, F3, F4):
Then there is this other cable conncted to the top left side of the controller
I will call it A (it has three little holes, two of them are close and the other one is more far).
I wanted to ask whether:
1) I should just plug a sata cable from the power supply to the bottom of the controller; or
2) Do 1) and then connect F1, F2, F3, F4 to the motherboard; or
3) Do 1) and 2) and then connect A to the motherboard; or
4) Do 1) and connect just A to the mother board;
and also where I am supposed to plug F1, F2, F3, F4, A on the motherboard which is an ASUS ROG STRIX B650E-F
Thanks a lot in advance and sorry for the silly question but I have never done this before.
