Hello!
I bought a PC for my friend a week ago. I built them and everthing is working perfectly but I install 3 rgb fans Chieftec Tornado, when I run a pc and it appear that rgb is freezing (some lights are on and it isn't change color, some lights are off and some lights are works normally). I have researched all possible solution and it didn't solved yet. It connected to ARGB to motherboard. It connected to PSU. All three fans are connected to controller RGB. I installed Aura Sync for Asus. Nothing fixed as you can see in pictures.
Motherboard: Asus Prime Z590-P
PSU: ROG Strix 550W
Fans RGB: Chieftec Tornado
View: https://imgur.com/aeEpTuK
View: https://imgur.com/C6rWqNM
View: https://imgur.com/xuJEqDQ
PSU: ROG Strix 550W
