[SOLVED] fan works but 0 rpm in software rx 570
Hi friends
i will go crazy with a problem in my gpu.
fan rotates, but he is not recognized by the motherboard, and in any software, even the amd one, I change a fan curve, but it has no effect, it is a rx 570, which was purchased on aliexpress, it was used in mining probably i will send images of the situation
I've checked or noise, it's the same, it doesn't change even at 89 degrees
i have an:
xfx rx 570 1286/1750
B75 Huananzhi
i5 3570 3,4
4x2 ram 1333
vídeos:
i make undervolt 1150 to 1090
and set up fan curve 40 50 60 70 80
(I've already reinstalled the bios, and i've tried to use the secondary)
(Sorry my bad english
and "not cheinge cheinge cheinge")
(i already asked for refound)
connector is 4 pin, see if all 4 wires are fine there
as for sensor (reporting fan speed) that would be yellow pin
