Question Fans problems
Jan 29, 2021
Hello guys, I hope you can help me. I recently bought Fan controller Deepcool 4-port Fan HUB FH-04 and 3 Fans SilentiumPC Sigma HP Corona RGB 120mm witch I connected on my ASUS PRIME H310M-R R2.0 on CHA_FAN. I can't see in bios and Asus aura it is not detecting anything. The 4 pin is not working when I connect the wires to the Fan hub but when I connect the 3 pin is working but without RGB. What can I do?
You have to describe better - which plugs go to which headers/
Fan hub controls fan speeds only. 1 connection to MoBo and all fans connect here.
However web page states "fixed speed of 1600 Rpm" so you may not have speed control (are they 3 wire fans ?)
In the second link which configuration are you using? bottom of page
https://www.deepcool.com/download/pdf/FH04_EN.PDF
