G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Group,
I suspect I'm greenhorning things up here and hope someone with some
experience will take time to straighten me out.
I'm trying to record from a collection of homemade cassette tapes to
computer file. That is, to mp4 or something similar.
I find that getting from tape to electronic file causes the volume
capabililties to weaken. That is, on tape I can lift the roof, but
once recorded to mp4 or *.wav I need pretthy high volume setting to
hear normally.
The hardware is a sony cassete deck.
Soundcard is SB Audigy2 ZS Platinum Pro
OS = windows xp pro
I've used software that is supposed to allow you to compensate
somewhat. Goldwave, and SB Audigy2 soundcard bundled software that is
a recorder/player with a slide for setting input level.
I find the amount of ajustment is very small. In some cases it seems
to be non-existent.
I'm thinking this is really a hardware problem. That I need something
inbetween that can boost the signal or something.
Maybe something like the cards suggested in a post here:
http://www.m-audio.com/index.php?do=products.list&ID=pciinterfac
Do these have capability to make incoming tape data
Thinking about that I realized I don't really have a clue what I'm
doing.
What is a normal way or tried and tested way of doing this?
Group,
hear normally.
OS = windows xp pro
to be non-existent.
doing.
