Archived from groups: comp.sys.hp.hardware (
More info?)
I've got a HP ze5300 laptop with the Sony DW-P50A DVD+RW - I upgraded the
firmware to 1.8f but can't still write to a spindle of 25 TDK DVD+RW 4x
(that says 2.4x compatible on the box).
I'm using Nero 6.0.0.0
Any ideas anyone?
Is there another firmware available?
I never got the chance to try it on 1.8c/e - would it make a difference?
Is there anywhere to get them?
Here's the error log that nero gives out:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created
28/05/2003 6:53:46 PM
ahead WinASPI: File 'C:\Program Files\Multimedia\Nero6\Nero\Wnaspi32.dll':
Ver=2.0.1.56, size=163910 bytes, created 2/04/2003 8:13:44 AM
Nero version: 6.0.0.0
Recorder: <SONY DVD+RW DW-P50A> Version: 1.8f - HA 1 TA 0
- 6.0.0.0
Adapter driver: <atapi> HA 1
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SONY DVD+RW DW-P50A >Version: 1.8f - HA 1 TA 0
- 6.0.0.0
=== Scsi-Device-Map ===
DiskPeripheral : IC25N080ATMR04-0 atapi Port 0 ID 0
DMA: On
CdRomPeripheral : SONY DVD+RW DW-P50A atapi Port 1 ID 0
DMA: On
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 82837504 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 574MB (588784kB)
Free physical memory: 160MB (164620kB)
Memory in use : 72 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
8.6.2004
ISO compilation
10:47:39 AM #1 Text 0 File Isodoc.cpp, Line 5451
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
10:47:39 AM #2 Text 0 File Reader.cpp, Line 118
Reader running
10:47:39 AM #3 Text 0 File Writer.cpp, Line 127
Writer SONY DVD+RW DW-P50A running
10:47:39 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3814
First writeable address = 0 (0x00000000)
10:47:39 AM #5 Text 0 File Burncd.cpp, Line 3081
Turn on Disc-at-once, using DVD media
10:47:40 AM #6 Text 0 File DlgWaitCD.cpp, Line 224
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 711599 (158:07.74)
10:47:40 AM #7 Text 0 File DlgWaitCD.cpp, Line 229
Write in overburning mode: FALSE
10:47:40 AM #8 Text 0 File DlgWaitCD.cpp, Line 1688
Recorder: SONY DVD+RW DW-P50A, Media type: DVD+RW
Disc Manufacturer ID: RICOHJPN, Media Type ID: W11, Product revision
number: 1
Disc Application Code: 0, Extended Information Indicators: 1
10:47:40 AM #9 Text 0 File ThreadedTransferInterface.cpp, Line 757
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 711600 (711600) = #711600/158:8.0
relocatable, CD pos for caching/writing not required/required, no
patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length
711600 blocks [SONY DVD+RW DW-P50A ]
10:47:40 AM #10 Text 0 File Burncd.cpp, Line 3318
Recorder and media-info
Burning to SONY DVD+RW DW-P50A on a DVD+RW media
10:47:40 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 910
Prepare recorder SONY DVD+RW DW-P50A for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 1457664000
10:47:40 AM #12 Phase 24 File dlgbrnst.cpp, Line 1818
Caching of files started
10:47:40 AM #13 Phase 25 File dlgbrnst.cpp, Line 1818
Caching of files completed
10:47:40 AM #14 Phase 36 File dlgbrnst.cpp, Line 1818
Burn process started at 2.4x (3,312 KB/s)
10:47:40 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2104
Verifying CD position of item 0 (relocatable, CD pos, no patch infos,
orig at #0): write at #0
10:47:40 AM #16 Text 0 File Cdrdrv.cpp, Line 7827
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer
Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM,
DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 01 52 49 43 4F 48 4A - 50 4E 57 31 31 01 39 23
..RICOHJPNW11.9#
00 8A 86 68 02 26 00 8A - 86 70 02 28 00 8A 86 6A
...h.&...p.(...j
02 28 22 12 10 E0 00 F0 - 00 00 00 00 00 00 00 01
10:47:40 AM #17 Phase 98 File dlgbrnst.cpp, Line 1818
Start formatting disc before burning
10:47:40 AM #18 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 8:02,968 (482968ms) -> OK
10:48:08 AM #19 Phase 100 File dlgbrnst.cpp, Line 1818
Formatting disc was successful
10:48:08 AM #20 Phase 65 File dlgbrnst.cpp, Line 1818
10:48:08 AM #21 Text 0 File DVDPlusRW.cpp, Line 513
Start write address at LBA 0
DVD high compatibility mode: Yes
10:48:11 AM #22 SCSI -1046 File Cdrdrv.cpp, Line 1361
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x08850000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x10
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x30 0x10
10:48:11 AM #23 CDR -1046 File Writer.cpp, Line 335
Illegal disc
10:48:11 AM #24 Text 0 File ThreadedTransfer.cpp, Line 227
all writers idle, stopping conversion
10:48:11 AM #25 Text 0 File ThreadedTransfer.cpp, Line 221
conversion idle, stopping reader
10:48:11 AM #26 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 0:00,000 (0ms) -> OK
10:48:11 AM #27 Text 0 File dlgbrnst.cpp, Line 1678
10:48:11 AM #28 Phase 38 File dlgbrnst.cpp, Line 1818
Burn process failed at 2.4x (3,312 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created
28/10/2003 8:02:00 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920),
size=86912 bytes, created 29/08/2002 1:27:50 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs
: 0 (Security Option)
