[SOLVED] First build advice,replies much appreciated
savvth01
Commendable
Aug 26, 2018
19
Hi, i will build a high-end PC in a couple of days and i want to see what you guys think of the parts i selected.. are they okay? is something not worth buying? etc..
just to clear things up im a newbie at computer building and stuff so the thing i put into the build are from internet search for days..
The build will be :
MOTHERBOARD : ASUS PRIME X570-P
RAM DDR4 : G.SKILL TRIDENTZ DDR4 16GB (8X2)
M.2 SSD : Samsung 970 EVO Plus 250 GB NVMe M.2
HDD : 1TB WESTERN DIGITAL
CPU : AMD RYZEN 7 3700X
GPU : RTX 2070 SUPER 3X FAN
PSU : EVGA SuperNOVA 850 G3, 80 Plus Gold 850W
PC CASE : Corsair Carbide Series SPEC-05 Mid-Tower Gaming Case
i want to know your opinion on this build or if i change something.. thanks!
EDIT : do you think the stock cooler on the CPU will be a good idea? ive been told 3700x has a good stock cooler.. whats your opinion?
The build will be :
EDIT : do you think the...
The build will be :
It looks like a good build but the PSU is overkill, You can go for a 650w PSU and still have allot of headroom for overclocking. Maybe get an 2TB hdd with the money you save.
And yeah, You should be fine with the stock cooler.
