Hello all, I was hoping the awesome folks here could give me advice on my build since it has been ages since I've done this before. I want to make certain there aren't any conflicts within the build and that the parts I've chosen are of sound quality. The build is linked below; any and all feedback is appreciated.
I really want to make certain I haven't picked out a configuration that isn't idiotic in some way (like cooler doesn't fit or is there not enough clearance for the RAM) so any mistakes you may catch are much appreciated. If you recommend any other components or configurations that are appreciated as well. Also, I think if I wait for a couple of months as the newer RTX cards come out the prices on the existing RTX 3k series will likely drop? Thank you for your time.
https://pcpartpicker.com/user/kinkykraken/saved/#view=9s2Lcf
- This is primarily meant for productivity. I am software developer and need lots of CPU and memory, not to mention HD speed, to run many instances of Visual Studio and other applications. I think 64GB is overkill but at that price vs the rest of the system why not?
- I play games, but mainly Factorio, City Skylines, Oxygen Not Included, RTS, and the like. Also, retro emulation. I do not play FPS, generally stay away from AAA titles, though if I had the power, I may check out one or two occasionally. But most of these games are really CPU and memory bound not so much GPU.
- I maybe would like to plug in an older VR headset, this is not required if it's too much money.
- My monitor is 1080p, but will eventually get a 4k ultrawide, multi-monitor setup, 4k used for productivity and the 1080p used for gaming.
Component | Selection | Price |
CPU | Intel Core i9-12900K 3.2 GHz 16-Core Processor | $564.99 |
CPU Cooler | ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler | $107.34 |
Thermal Compound | Arctic Silver 5 High-Density Polysynthetic Silver 3.5 g Thermal Paste | $7.25 |
Motherboard | MSI PRO Z690-A ATX LGA1700 Motherboard | $144.97 |
Memory | Corsair Vengeance 32 GB (2 x 16 GB) DDR5-4800 CL40 Memory | $149.99 |
Storage | Seagate FireCuda 520 2 TB M.2-2280 NVME Solid State Drive | $179.99 |
Video Card | EVGA GeForce RTX 3070 Ti 8 GB XC3 ULTRA GAMING Video Card | $652.05 |
Case | Fractal Design Torrent ATX Mid Tower Case | $206.35 |
Power Supply | Enermax Revolution D.F. 850 W 80+ Gold Certified Fully Modular ATX Power Supply | $104.99 |
Wireless Network Adapter | TP-Link Archer TX50E 802.11a/b/g/n/ac/ax PCIe x1 Wi-Fi Adapter | $49.99 |
Total: | $2317.90 |
