First Build, Need CPU Heatsink Advice
deathtoll
7
Ok, So I am building my first PC and am on a slight budget, here is a list of my parts so far.
Case: Cooler Master HAF 932 Advanced - http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119160
Mobo: ASRock Z68 Extreme3 Gen3 - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157271
CPU: Intel Core i5-2500k 3.3GHz (3.7 Turbo Boost) - http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115072
RAM: G.SKILL Ripjaw Series DDR3 1333 x 16gb - http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231402
PSU: OCZ ZS Series 750W - http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341049
GPU: EVGA Geforce gtx 560 Ti 1GB - http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130623
Windows 7 64bit Home Premium
Basically what I am asking for, is what heatsink/fan should I be using? As you can see with that mobo I have limited room,
and because of that particular RAM, I cannot use one that is too large.
Another thing I was looking it was having the air blow out the TOP of the Case, as there is a fan located there on the HAF 932 Case. I'm kind of looking at a 50 dollar price range, willing to go a bit more if it fits nice and doesn't look fugly.
-Update-
So far I've been looking at http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103100&Tpk=COOLER%20MASTER%20GeminII%20S524
as well as http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103065&Tpk=RR-B10-212P-G1
But am still open to suggestions. I am ordering all of these parts tomorrow or the day after max, as there is currently a sale on some of the parts
I should also mention I will eventually be overclocking this CPU
The difference really becomes slight with the addition of a second fan on the plus. :)
I'm guessing he's following intel's spec's for the i5.
+1 to Chesteracorgi from me. I recently bought the antec 620 and I am very happy with it. Its a closed loop cooler meaning that you will have lots of space free in the cabinet if you compare with the 212 evo.
Its true that some air coolers perform better but my i5-2500k oc to 4.1 Ghz, is at 65c after 1 hour in prime95, and at idle its usually cooler than the mobo. Also its very silent which I prefer when I buy coolers.
Doing some research I find that the differences between 1333 and 1600 for ram is quite small when using Sandy Bridge because it supports up to 1333. Regardless it is an upgrade from the current 8 gb I am using now.
Looking up reviews on the Antec 620 it seems that the cost to cooling ratio isn't worth the price, and suggest getting a good air cooler for the price.
I am still leaning towards the 212 Evo, but like I said I'd like it aimed towards the top of the case if possible, but I don't know if it will clear that ram.
Now, on the other hand, do the heat sinks on those RAM in particular cool the ram that much?
Not really. They just help dissipate some of the heat generated.
They do sell fan setups for ram if you want something more "active".:)
Good choice - the Cooler Master is the way to go - either model would do. Fans for your ram are not really needed (except by the "extreme" overclockers/gamers - maybe). Good luck with your new build. :)
Thanks =)
I only mentioned the heat sinks on the ram because it can be in the way of the cooling systems on some CPU cooling units and was wondering if low profile ram can cool as good as the Ram I have linked up top in my build.
Yes. Low-profile will be fine.
