First Computer Build - Help Requested
DigitalCurruption
Hi there! I am looking to build a computer (about $1800 price range) and I was wondering if this build is fine. This is my first time so I would like some help on my parts! I need the mouse, keyboard, and monitor so please don't remove them.
The build:
http://pcpartpicker.com/p/3RkY3
Also if you can, may you please try to fit a single GTX 780ti instead of SLI GTX 760 TF?
Thx!
Edit:
Managed to get in GTX 780ti but considering R9 290x.
Check here for the update: http://pcpartpicker.com/p/3RlQq
Rule #1 Never go dual cards if a single card can do the same thing. You don't get double the performance and some games run like crap regardless.
Edit:
There is a R9 290X on sale for under $500 after rebate with New egg. I'm on my phone right now but shouldn't be hard to find. It trades blows with the 780 ti depending on the game and is hella cheaper.
Edit:
Okay! I'll consider it and will post back! Thanks!
