APPROXIMATE PURCHASE DATE: June 2009
BUDGET RANGE: $1000, I can go a little over though
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: programming projects, circuit board design / simulations, school work, games, surfing the net, I will be doing some stereo machine vision projects, small amounts of audio rendering
PARTS NOT REQUIRED: keyboard and mouse
PREFERRED WEBSITE(S) FOR PARTS: Newegg
PARTS PREFERENCES: I have previously been an intel fan but am willing to give AMD a try
OVERCLOCKING: Most Likely.
SLI OR CROSSFIRE: Sure
MONITOR RESOLUTION: I have a 22" 1680 x 1050 and a second monitor, a 20" 1440 x 900 is included in the build.
This will be my first build ever, my laptop with 2GB DDR2 memory and a dual core intel processor can be very slow sometimes, I would really like a dedicated desktop machine that will last a few years.
I have spent a long time trying to decide on the right parts. Here's sort of where I started out and where I am in deciding what to build.
I started out with DDR3 memory and one of the new i7 processors, decided it was too expensive, scaled it back to a system based on the intel Q9550. This was more in my price range but I would still like to cut costs.
At this point I started looking at the AMD processors, I have some friends that are big fans of AMD so I thought I would check it out.
Right now I am trying to choose between two different setups. One uses the AMD Phenom II X4 940 Deneb 3.0GHz AM2+ 125W Quad-Core Black Edition and the other is the intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core. I am slightly interested in overclocking, like maybe bumping the AMD to 3.2 or the intel to 3.0.
So these are the goals for this thread:
Pick out a video card:
EDIT: I found the graphics section of the forums, I have one picked out now!
Choose between processors:
Like above I'm trying to choose between the Intel Q95500 or the AMD Phenom X4 940. I would like it to last me a few years. I'm trying to figure if it's worth the extra money to for the intel. Right now I'm leaning toward the AMD because I "think" it should be fine for me, but I don't really know, and it's cheaper.
Cut some costs, swap some parts out for what I really need, questions:
I've attempted to do this myself, trying to have quality parts of only what I need. I had decided on getting an HP 23" 1080p monitor but by cutting it down to a 20" 1440 x 900 I saved $100. Am I going to notice the difference between 4, 6 or 8 GB ram? I don't if 4 is enough, 8 seems like overkill, I'm really not sure what to do here. Is my PSU too much, about right? Also, very important, I'd like to make sure all my hardware is compatible with each other.
Well here's what I've come down to for my build list on Newegg:
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model
Model #:OCZ2RPR10664GK
Item #:N82E16820227289
$72.99 X 2
$129.98
Western Digital Caviar SE WD3200AAJS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
Model #:WD3200AAJS
Item #:N82E16822136098
$49.99 X 2
$99.98
EVGA 512-P3-N841-AR GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported
Model #:512-P3-N841-AR
Item #:N82E16814130325
#104.99
KINGWIN ADP-02 HDMI Female (19 pin) to DVI-D Male (24+1 pin) Adapter - Retail
Model #:ADP-02
Item #:N82E16812226015
$9.99 X 2 -$4.00 Instant
$11.98
Arctic Silver 5 Thermal Compound - OEM
Model #:AS5-3.5G
Item #:N82E16835100007
$8.99
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
Model #:ACFZ7-PRO
Item #:N82E16835186134
$36.99 -$5.00 Instant $31.99
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
Model #:AD-7240S-0B
Item #:N82E16827118030
$23.99
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail
Model #:Three Hundred
Item #:N82E16811129042
$69.95 -$15.00 Instant $54.95
HP 2009m 20" HP 16:9 Wide HD Ready LCD Flat Panel Monitor - Retail
Model #:2009M
Item #:N82E16824176112
$159.99 -$20.00 Instant $139.99
GIGABYTE GA-MA790GP-UD4H AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - Retail
Model #:GA-MA790GP-UD4H
Item #:N82E16813128384
$139.99 -$10.00 Instant $129.99
OCZ StealthXStream OCZ700SXS 700W ATX12V / EPS12V SLI Ready CrossFire Ready Active PFC Power Supply - Retail
Model #:OCZ700SXS
Item #:N82E16817341019
$99.99 -$10.00 Instant $89.99
AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HDZ940XCGIBOX - Retail
Model #:HDZ940XCGIBOX
Item #:N82E16819103471
Return Policy😛rocessors (CPUs) Return Policy
In Stock
$214.99 -$25.00 Instant $189.99
Total Build Cost: 1016.81
Thanks!
$72.99 X 2
$129.98
Model #:WD3200AAJS
$49.99 X 2
$99.98
#104.99
Model #:ADP-02
$11.98
Model #:AS5-3.5G
$8.99
Model #:ACFZ7-PRO
Model #:AD-7240S-0B
$23.99
Model #:2009M
Model #:OCZ700SXS
In Stock
Thanks!
