[SOLVED] First pc build help
May 11, 2020
So this is gonna be my first pc build when ever, I will probably get it when the dreadful quarantine ends but this is the parts picker and I would appreciate if someone confirmed if the products are compatible and if this pc build is good enough for years to come. HAIL THE MASTER PC RACE
https://pcpartpicker.com/list/kgNZK4
Tweaked the build further. I changed the slow CAS20 3600MHz RAM from the build to CAS16 3600MHz RAM. Changed the SSD for the Crucial P1 1TB. The PSU for the RMX instead of the RM which is of better quality.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor ($204.99 @ B&H)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ Best Buy)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory ($84.99 @ Amazon)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive ($119.99 @ Newegg)
Video Card: ASRock Radeon RX 5700 XT 8 GB CHALLENGER D OC Video Card ($359.99 @ Newegg)
Case: Corsair SPEC-DELTA RGB ATX Mid...
I tweaked your build a little bit: https://pcpartpicker.com/list/8jPGRk
Bassically i put the 3600x and rx 5700 xt and still manage to be get a better build(in my opinion)+saved 70$ for a headset or something
Reactions: Nelly223
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case ($79.99 @ Best Buy)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($134.99 @ Newegg)
Monitor: MSI Optix G241 23.8" 1920x1080 144 Hz Monitor ($189.99 @ B&H)
Keyboard: Redragon K550-W RGB Yama Wired Gaming Keyboard ($84.99 @ Amazon)
Mouse: Corsair M65 RGB ELITE Wired Optical Mouse ($49.99 @ Best Buy)
Total: $1614.89
Generated by PCPartPicker 2020-05-11 08:26 EDT-0400
Reactions: Dj0gany
Your build will work as is.
If I have one suggestion, it is to dump the hard drive unless you will store large sequential files such as videos.
500gb will hold a fair number of games. It is easy to add storage later when you need it.
Or, consider a 1tb ssd up front.
It makes little difference if it is a m.2 pcie drive or a conventional 2.5" sata ssd.
Pcie is faster sequentially, but you will not notice the difference since most activity is small random I/O.
I like intel and samsung best. They make their own components and can do a better job of quality control.
On a budget, a 1tb intel 660P m.2 is very good.
For maximum performance, look to a 1tb samsung 970 evo +
Intel 10th gen is due to launch soon.
I might wait on processor selection to see what it brings.
At the very least, there may be price adjustments.
I suspect some ryzen buyers are going to have buyer's remorse.
FWIW:
MY build process:
Before anything, while waiting for your parts to be delivered, download
and read, cover to cover your case and motherboard manual.
Buy a #2 magnetic tip philips screwdriver.
I find it handy to buy a power switch like this for testing.
https://www.ebay.com/p/4in1-PC-Powe...or-Computer/631889283?iid=142232821294&chn=ps
1. I assemble the critical parts outside of the case.
That lets me test them for functionality easily.
A wood table or cardboard is fine.
2. Plug in only the necessary parts at first. Ram, cpu, cooler, psu.
Do not force anything. Parts fit only one way.
Attach a monitor to the integrated motherboard adapter if you have one, otherwise to the graphics card.
  1. If your motherboard does not have a PWR button, momentarily touch the two pwr front panel pins with a flat blade screwdriver.
  2. Repeatedly hit F2 or DEL, and that should get you into the bios display.
  3. Boot from a cd or usb stick with memtest86 on it. memtest will exercise your ram and cpu functionality.
  4. Install windows.
  5. Install the motherboard cd drivers. Particularly the lan drivers so you can access the internet.
Do not select the easy install option, or you will get a bunch of utilities and trialware that you don't want. Drivers only.
  1. Connect to the internet and install an antivirus program. Microsoft security essentials is free, easy, and unobtrusive.
  2. Install your graphics card and driver if you tested with integrated graphics.
You will need to remove the graphics card later to install your motherboard in the case.
As a tip when screwing the motherboard into the posts, give the screw a small counterclockwise turn until you feel a click.
That lets you know that the screw will engage properly.
Make a note of how the graphics card latches into the pcie slot.
The mechanism will be hidden under the card and may be difficult to work if you have not previously checked how.
  1. Update windows to currency.
  2. Only now do I take apart what I need to and install it in the case.
  3. Now is the time to reinstall your graphics card.
FWIW:
MY build process:
  4. Install windows.
https://pcpartpicker.com/list/2PhxQq
This is my updated parts list I’ve been in other forum and watching benchmark videos what do you think of this. I also don’t mind the slower speeds but coming from a ps4 with 500gb memory I wanted 2tb and I’ll put games i play more often on my ssd
Total: $1614.89
I don’t mind the slower ram I wanted some rgb just for vanity but when I go to upgrade parts I’ll prolly pay more for a faster ram but for now I think I’m gonna go with this. What do you think? I’d hope I don’t have to upgrade the rtx 2070super for like 4 years at least even when I run high settings on games like cod,gta, rainbow and etc?
Latest posts
