First time build. Need some help!
waffleeez
8
Hey everyone.
This is my first time building a computer. I've put a list of parts together and I was looking for some input. The computer is going to be used for gaming and I am looking to overclock. Any recommendations for better value, performance, etc. would be greatly appreciated.
I play mostly FPS's but do plan on playing games like DayZ in the future.
Anyway, here's what I have so far.
CPU: Intel Core i7 3770k NewEgg
MoBo: ASRock Z77 Extreme4 LGA 1155 NewEgg
RAM: Corsair Vengeance 8GB (2x4GB) NewEgg
GPU: EVGA GeForce GTX 660 Ti 2GB NewEgg
Case: Cooler Master HAF 922 NewEgg
PSU: Corsair Enthusiast TX 650 W ATX 12 NewEgg
Thank you in advance!
Those parts are all fine. I would drop the i7 to an i5 3570k, since for gaming you don't need the i7's hyperthreading, and I would use the savings to upgrade the GPU to a 670 (Gigabyte makes a very good one).
Also, if you intend to OC you'll need a CPU cooler. I recommend the Hyper 212 Evo and the Noctua D14, depending on how much money you intend to spend. The 212 Evo is quite cheap and has great performance, while the Noctua has better performance (though it won't matter on a small OC) but is more expensive.
I didn't put it in the original post but I have put down a heatsink. Its the Phanteks PH--TC14PE. Link
Ok, then in that case you're "cool" (get it? 😛)
Yep, so I'd just change the CPU and get a 670. Other than that you're good :)
Haha Nice one 😉
Just one more question. What brand would you recommend getting the new GPU from?
Gigabyte makes what I think is the best 670, it has great cooling and is pretty quiet.
Here's an article from Toms comparing several 670s. According to them, the standouts are Asus for noise, Zotac for performance, and Gigabyte all-around. http://www.tomshardware.com/reviews/geforce-gtx-670-test-review,3217-16.html
Thanks for the great advice! 😀
