I have recently gotten into overclocking, attempting to overclock my i7-9700k to 5.0Ghz. I did some benchmarking using Cinebench R15 to track my performance gains. I noticed that when I ran the test concurrently, the first 2 tests will run just fine on the overclocked frequency, but all subsequent tests will seemingly reduce the clock speed down to around 4.6 Ghz (oddly enough, my benchmark score still remained the same). The same thing happened when running an Aida 64 stress test, with the clock speeds dropping after about 2 minutes in.
Naturally, I thought this pointed to a VRM issue, but because my motherboard doesn't have an actual VRM temperature sensor, there was no way to tell. So, I tried downloading Intel's XTU software, and upon running a normal CPU software, everything seemed fine. However, when I ran a test with AVX instructions, it told me that it was the current/EDP limit that was throttling my CPU, and not my VRMs.
I scoured all over the web for a remedy, trying to increase my the CPU current capability along with the long/short package power limit and the package power time window on my BIOS, but neither did solve the problem. In fact, the latter two actually crashed my system. After trying an AVX offset of 2, was I finally rid of the problem. Now, the stress tests with AVX just runs at 4.8Ghz instead of fluctuating all over the place.
So my question is, or rather, are: are there any other solutions to fix a current/EDP limit throttling other than an AVX offset? Also, will an AVX offset negatively impact performance in games?
My full specs are as below:
CPU: Intel Core i7-9700k OC@5.0Ghz
CPU Cooler: NZXT Kraken x63
RAM: 2x16GB Corsair Vengeance RGB PRO DDR4 3200mhz CL16
MOBO: Asus Prime z370A-II
GPU: Zotac GTX 1060 Mini (6gb)
PSU: Cooler master 750W MWE Gold (Full modular)
Thanks in advance.
Thanks in advance.
