Floppy drive problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I recently had to format my hard drive and reload Win XP Pro in
"Standard PC" mode to use my recording software. I did this about two
weeks ago.
Today, I tried to put a floppy into the drive, and I got a "The
request could not be performed because of an I/O error" message. This
happened several times. So I checked the cables and turned the
computer back on, and now all I get is a "Please insert a disk into
the drive" message, even when there is a disk in there. The disk reads
in my other computer. By the way, I am on Service Pack 1.
Can someone give me some ideas?
Thank you in advance.
remove "nospam" to reply
In news:k78n211h3bc2409uu7736b7e146a2506sh@4ax.com,
Glenn & Cheryll Martin <overmyheadnospam@earthlink.net> had this to say:
> weeks ago.
As I was scrolling through I found a good post just moments before opening
this newsgroup and reading your request. The information is well put and
very organized so I'll copy the entire thing here for you. Please thank the
author of the post (not me) should it be the answer you're looking for as it
has been for me in the past:
I had the same problem with 2 XP systems, different floppy manufacturers. I
read a long-time back on this NG a long history of the problem. Essentially
Microsoft KB 309623 says WinXP supports only 1.44MB disk format. 3-mode FD's
capable of reading/writing 720KB, 1.2MB and 1.44MB require special driver
support and support for this feature is not included in Windows XP. See
following:
http://support.microsoft.com/default.aspx?scid=kb;en-us;309623
The writer (and I can't recall who that was) did some exhaustive research
and found a place for a driver. I downloaded that driver and it cured my
no-format problem on the PC that was giving trouble. Now both PCs can format
and read the floppy disks. Driver link (this is a download only):
http://downloads.viaarena.com/WinXPE/Oct02/XPe_3mflp132_v10.zip
Instructions as outlined in the writer's article:
1. Download driver
2. Unzip the driver - extract the file to a folder.
3. Open Windows XP's Device Manager, expand the "Floppy disk controllers"
heading, and double-click the listing for "Standard floppy disk controller."
4. Click the "Driver" tab, then click the "Update Driver" button.
5. Select the "Install from a list or specific location" radio button and
click the "Next" button.
6. Select the"Don't search. I will choose the driver to install." radio
button and click the "Next" button.
7. Click the"Have Disk" button; then, click the"Browse" button. Browse to
the location that you extracted the files to in Step 2 and double-click the
"VIA3MFPY.INF" file. The, click the"OK" button.
8. You should now have "VIA 3-mode floppy controller" highlighted in the
drivers list. Click the "Next" button to begin the driver file copy. Once
the file copy is complete, your floppy disk drive will access 3 times
(checking all 3 "modes"). This is normal. Click the "Finish" button when the
driver installation is complete.
9a. You may, or may not , have a device labeled "Unknown Device" in
the"Other Devices" heading in Device Manager. If so, continue with step 9a.
If not, skip to step 9b. If you have a device labeled "Unknown Device" in
the "Other Devices" heading in Device Manager, right-click on it and select
"Update Driver." Follow steps 5 through 8 to complete the installation of
"Floppy disk drive" (note that the naming of the driver in the drivers list
in step 8 may be different during this step - this is normal). Once you've
click the "Finish" button, continue on to step 10.
9b. If you do not have a device labeled "Unknown Device" in the "Other
Devices" heading in Device Manager, expand the "Floppy disk drives" heading
in Device Manager and double-click the listing for "floppy disk drive."
Follow steps 4 through 8 to complete the installation of "Floppy disk drive"
(note that the naming of the driver in the drivers list in step 8 may be
different during this step - this is normal). Once you've clicked the
"finish" button, continue on to step 10.
10. Reboot your PC. This should let you know if all of your hard work
REALLY paid off. Check the Device Manager one last time to be sure that you
now have the"VIA 3-mode floppy controller listed under the "Floppy disk
controllers" heading. Put a file on a floppy in Win98 (or another non-SP OS)
and you should now be able to access it in Windows XP (and vice-versa)
without issue. You made it!
If this helps anyone, the credit isn't mine -- I wish I could recall the
originator. There was much more background given about his research
including another web site. Unfortunately I only have the printed out
document. If there is any further interest in the entire article I would be
willing to scan and post it.
"ghawthorn" <ghawthorn.1lgj1m@pcbanter.net> wrote in message
news:ghawthorn.1lgj1m@pcbanter.net...
> cannot read floppies made with w98 on my wXP home. Anyone else have that
> problem?
> ghawthorn
Again, keep in mind that the post is not mine, it's from a Gene Hora and was
in microsoft.public.windowsxp.newusers though I couldn't have put the answer
better myself.
Galen
"My mind rebels at stagnation. Give me problems, give me work, give me
the most abstruse cryptogram or the most intricate analysis, and I am
in my own proper atmosphere. I can dispense then with artificial
stimulants. But I abhor the dull routine of existence. I crave for
mental exaltation." -- Sherlock Holmes
Hi Galen,
I did exactly what you posted, and now my computer takes forever to
boot up, and the drive still doesn't work. So I removed those drivers,
and the system boots normal again, but the drive still does not work.
Do you have any other suggestions?
Thanks in advance.
In news😛rfn2191cta1gota2p80m37nh501unvlku@4ax.com,
Other than hardware (cables or drive itself) none other than the BIOS
suggestion given to you already. The "usual" fix is the drivers. If they
made your PC boot slower but work on other three mode drivers that makes me
think that hardware is more likely your issue if it's recognized at all in
the hardware device manager.
Galen
This floppy driver is only for VIA chipsets.
"Galen" <galennews@gmail.com> wrote in message
news:%23Dt44SrIFHA.3076@tk2msftngp13.phx.gbl...
>> weeks ago.
> the author of the post (not me) should it be the answer you're looking for
> as it has been for me in the past:
> I
> Essentially
> FD's
> following:
> format
> 1. Download driver
> controller."
> the
> the
> 9a.
> select
> list
> heading
> drive"
> you
> OS)
> be
>> problem?
>> ghawthorn
> was in microsoft.public.windowsxp.newusers though I couldn't have put the
> answer better myself.
> Galen
Is the drive recognized in the device manager? By any chance, at any point,
did the floppy cable get unplugged, and plugged back in? Some floppy drives
do not have a notch which ensures that 'cable 1', usually marked by a red
stripe on the floppy cable, corresponds to 'pin 1' on the drive. Also, any
chages in BIOS settings? There are a few floopy modes to choose from in most
BIOS settings.
Worth a shot...
"Glenn & Cheryll Martin" <overmyheadnospam@earthlink.net> wrote in message
news😛rfn2191cta1gota2p80m37nh501unvlku@4ax.com...
> Hi Galen,
> Thanks in advance.
In news:e$hD4TyIFHA.1948@TK2MSFTNGP14.phx.gbl,
Yves Leclerc <yleclercNOSPAM@maysys.com> had this to say:
Having only one old computer with XP on it with the outdated three mode
floppy I dug it out and (I don't/won't own a VIA) it's an Intel i845GV in a
Dell Dimension 2400. I did mention it was old. The current drivers didn't
allow for a floppy to be formatted. I downloaded and installed these same
drivers. I rebooted. I formatted a floppy. What does this mean? It means
that it works for me though it may not work for the everyone it's the only
floppy drivers that I've known right off hand that cure the XP Floppy Blues
unless your setup specifically offers a single mode for the floppy. Which,
thankfully, many do though still others do not. Beyond that I'm not sure
what to say unless it's a hardware issue and floppy drives tend to be pretty
sturdy creatures though their ribbon cables don't last forever if there's
been a lot of movement inside the case.
Galen
Hello all,
Today for fun, I set my BIOS to boot from the A drive first. I
inserted a Data Lifeguard disk from Western Digital. It DID boot from
the disk. I cancelled the install and got the A prompt. I typed DIR,
and it read the disk. I exited to Windows, and tried to read the disk.
Didn't happen. Explorer and Device Manager do recognize the drive.
Thanks again for all the help.
Glenn & Cheryll Martin wrote:
| Hello all,
That disk is a PCDOS diskette. Also windows default is to hide
system files.
