For Kelly or other MVP > Automatic PPPoE connection on sta..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics,microsoft.public.windowsxp.general,microsoft.public.windowsxp.network_web (More info?)
I have a problem
I want my pc to automatically connect at start up and have tried the
following from kelly's site:
http://www.kellys-korner-xp.com/xp_p.htm#xp_pppoe
PPPoE - How to get PPPoE in Windows XP to log in Automatically on boot:
However my pc stalls at startup because I have many applications (that I
need and want) and it seems to skip
the pppoe connection. I have given an IP address to my nic ethernet ADSL
modem (since I read that there is a stall of 120 seconds if you dont do
that), but its still not working.
Then I read that there is a way with a bat file to do it, but I cannot find
a bat file on the internet, and I dont know how to make one.
Please does any one know of a way to accomplish this?
TIA
Since you are on DSL, you are in fact always connected. However, many DSL
setups require you to click to connect which is what I assume you are trying
to avoid. If you connect through a router, it will automatically connect on
bootup. Routers are now relatively inexpensive, you only need to configure
it initially for your password, ID and probably the domain which is, for
example, usually the part of your e-mail address that is to the right of the
"@" sign.
Once set up and configured, it works seamlessly and will connect on bootup
on its own. It has the added advantage of usually acting as a hardware
firewall which gives you extra protection and it masks your computer to the
outside world.
Michael Solomon MS-MVP
Windows Shell/User
https://mvp.support.microsoft.com/communities/mvp.aspx
Backup is a PC User's Best Friend
DTS-L.Org: http://www.dts-l.org/
"Kenny S" <hotmail@coldmail.com> wrote in message
news:exQlmnySFHA.204@TK2MSFTNGP12.phx.gbl...
>I have a problem
> find a bat file on the internet, and I dont know how to make one.
> TIA
Hi
I suggest to people who are on DSL PPPOE to get a Router even if they are using single
computer.
The Router keeps the PPPOE Always Alive independent from the computer (so you can
uninstall the PPPOE software), as a result the Internet connection is more stable and
somewhat faster.
If you have an External Ethernet DSL Modem the cost of an inexpensive Router is less
than $20.
If you are on USB or Internal Modem you would need to buy an External Ethernet DSL Modem
(about $65).
More detailed help here: http://www.ezlan.net/PPPOE.html
Jack (MVP-Networking).
> I have a problem
> TIA
is it possible to start a connection as a service?
>I have a problem
> TIA
This is not my case since the modem needs to initiate the connection.
This is what I want to keep since I use the same connection for other remote
uses. (So i close the connection and use the same connection elsewhare)
No, I dont want a router, I only want a way for me to start the connection
after boot up, perhaps after 3 minuites. Is this possible with some program
or script?
This is because I want to be able to close the connection at will and the
connection to be free for use from another location.
I have found a program that makes the connection into a service, and I am
testing it out. The site is in french but the program is also in english
http://www.adslautoconnect.net/
But of course this consumes resources... all I actually need is a bat file
that can run a .lnk extension after a time interval... is this possible?
I dont want other solutions.. I want an answer to my question.
"Michael Solomon (MS-MVP)" <user@#notme.com> wrote in message
news:OmNKM81SFHA.2560@TK2MSFTNGP09.phx.gbl...
> trying to avoid. If you connect through a router, it will automatically
> connect on bootup. Routers are now relatively inexpensive, you only need
> to configure it initially for your password, ID and probably the domain
> which is, for example, usually the part of your e-mail address that is to
> the right of the "@" sign.
> the outside world.
> Windows Shell/User
>>I have a problem
>> TIA
I'm sorry, that's all I really had for you. You might try this question on
the windowsxp.configuration_manage newsgroup.
Windows Shell/User
news:%23mJpyg2SFHA.3188@TK2MSFTNGP09.phx.gbl...
> remote uses. (So i close the connection and use the same connection
> elsewhare)
> program or script?
>> DSL setups require you to click to connect which is what I assume you are
>> bootup on its own. It has the added advantage of usually acting as a
>> hardware firewall which gives you extra protection and it masks your
>> computer to the outside world.
>> Windows Shell/User
>>>I have a problem
>>> TIA
NO , I want to be able to close the the connection manualy.
I dont need a router, since it created more problems that it solves,
I am using ICS as a software router.
or script?
"Jack (MVP)" <Jack(MVP)@discussions.microsoft.com.> wrote in message
news:uhf%23Gc2SFHA.3280@TK2MSFTNGP09.phx.gbl...
> Hi
> using single
> computer.
> you can
> stable and
> somewhat faster.
> Router is less
> than $20.
> Ethernet DSL Modem
> (about $65).
>> I have a problem
>> find
>> TIA
Use something like MSCONFIG to reorder your start up list or remove one of
the start up programs that takes the longest to load and then readd it after
reboot.
Otherwise, untick some of the items in MSCONFIG and place the shortcuts in
the startup folder.
>I have a problem
> TIA
On Wed, 27 Apr 2005 23:35:02 +0300, "Kenny S" <hotmail@coldmail.com>
I wouldn't touch that with a barge pole - this exposes your OS
directly to the Internet. Good luck with the patch race.
Gone to bloggery: http://cquirke.blogspot.com
In article <6l06715d9r1aquvab5job1a6mbehculbbd@4ax.com>, "cquirke (MVP
I think that using ICS as a software router is fine, and I've written
a web page showing how to do it:
Windows XP Internet Connection Sharing
http://www.practicallynetworked.com/sharing/xp_ics
Be sure to use a firewall to protect the host computer from access by
other Internet users. XP's built-in firewall can do the job quite
well.
Best Wishes,
Steve Winograd, MS-MVP (Windows Networking)
Please post any reply as a follow-up message in the news group
for everyone to see. I'm sorry, but I don't answer questions
addressed directly to me in E-mail or news groups.
Microsoft Most Valuable Professional Program
http://mvp.support.microsoft.com
On Sat, 30 Apr 2005 03:23:22 -0600, "Steve Winograd [MVP]"
>In article "cquirke (MVP Windows shell/user)"
Well, there's always the risk of direct network attack. That's higher
for XP as it is for Win9x, and when you move from a few minutes a day
of DUN with variable IP to always-on bband, it gets to the point where
I'd want all my Windows surfaces hidden behind NAT.
Then there's the egress traffic issue. Sometimes, something will
trigger attempts to dial out to access the Internet, and that prompts
a clean-up. With always-on bband, these attempts will always silently
succeed, unless a firewall blocks them. A router doesn't do much
(anything?) to help with this issue, though.
>other Internet users. XP's built-in firewall can do the job quite well.
The firewall is itself a risk surface, as Witty demonstrated, but yes;
I'd echo that advice. Firewalls get messy to set up (read; likely to
be set up wrong) when the same network adapter has to carry both LAN
F&PS traffic and Internet traffic. A harder edge, as provided by a
NAT router, helps offset this leaky internal separation.
