[SOLVED] Format without losing data
romi1000000
14
I am going to get a new motherboard next week and install Windows 10. I will install Windows to an SSD which doesn't have any personal data. I also have an internal HDD which has all my files in it. Will I be able to only format the SSD or is it necessary to do both of them?
No, if you don't touch it in the installer your data will still be there.
However, i suggest removing the drive just so you can't accidentally destroy the data on the drive.
